![]() | Home > Wheels & Tyres > Wheel nuts |
Try taking the plastic wheel nut cover off.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18028 ![]() ![]() ![]() |
Swollen nuts, a common problem! The steel nut under the chrome cover rusts and causes the cover to swell. The only practical solution is to replace the affected nuts.
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
You will have to hammer a socket onto the existing swollen nut, or try a 28mm single hex socket this may fit and work (if your nuts are swollen enough).
As mentioned you will have to replace your swollen rusty nuts. |
Little Tom Member Since: 20 Aug 2013 Location: Lancashire Posts: 134 ![]() ![]() ![]() |
Swollen nuts, knew someone else would have had my problem... Thanks very much for helping me with this delicate situation!
Had that with the last 4 vehicles with alloys fitted. All LR products and always the same response from main dealers - TADTS. Nobody seems interested in solving the issue. Another benefit of swapping back to steels wheels - plain steel nuts
