![]() | Home > Maintenance & Modifications > Outside Temperature in Blind Switch |
Never seen one, but another possibility may be a rear view mirror with temp. display, or a RDS sensor for display to the headunit. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
dotom Member Since: 04 Feb 2012 Location: Dortmund Posts: 95 ![]() ![]() ![]() |
Hi Vincent, the RDS unit is sold by CroyTec, but if you change your radio frequency the temp is gone. Mirror with built in temperature display may be quite difficult to realize. The blind switch is already there and not used. Behind it there is enough room for the electronic and it is always visible. There is only the problem to find an LCD display which is small enough to be fittet inside the switch.
Tom |
