![]() | Home > Puma (Tdci) > need to lower my new puma by 2-3 cm any ideas ? |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Make the garage bigger
thanks for the idea, but that can't happen, I need to lower it.
I don't really want to put smaller wheels on, otherwise I will end up with 9 235/85/16's I need to just change the rear springs but I need to know where I can get some from.. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2480 ![]() ![]() ![]() |
can`t you build some grooves on the pavement? I would not lower a landy Puma 110" SW
Find a couple of fat homeless people and offer them lodgings each evening in your Puma!
![]() Treat every day as if it is your last....one day you will be right!! |
Apynala Member Since: 17 Oct 2009 Location: Morroco Posts: 88 ![]() ![]() ![]() |
![]() A compressor ![]() |
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 ![]() ![]() ![]() |
park it outside
![]() wait till you try the underground parking...you might make the heighth, but the turning ramps will kill ya ![]() IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
I would really have liked some sensibe answers on here tonight but it seems you are all far too jolly to answer properly... still JonnyTurbo and I will have the last laugh when Gordon Brown gets back in to no. 10 ..
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
Spring compressors or ratchet straps?
Roll up garage door Mike |
110" is about 1.80 m wide
![]() Really, you do not mind to lower it!? Puma 110" SW ............................................................. Earth first. Other planets later |
![]() ![]() ![]() ![]() ![]() ![]() Erm...did you not take a tape measure if you knew you had size restrictions? You cannot teach stupid people to do clever things |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Go to a lower profile tyre or fit TD5 90 Springs? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
They won`t fit a 110 rear |
I would imagine that the main problem is you ( and I for that matter) have boost tire and rim set up whereas the steel units lower the height a bit, usually under the 2m mark. That might be an option, I have seen some, well one, with a lower profile tire on it. It looks, ok, only ok, and really, we are driving ours mainly on road so a lower profile wont make too much of a difference in what we are using our trucks for.
One thing that you will find comfort in is that here, when a sign says 2.05m high, it really is and we have trucks that are 2.025m high so we fit barely. Oh the joys of living in a country where most parking is underground...now if I could just find where they hide all the gold... 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
JT - I have just bought an ICE edition with the updated Boost alloys like on the 60th's, I really don't want to loose these.
I was recently at a land rover garage at Gland, there was a guy there from Geneva who was had 2 sets of rear springs, a city set and a safari set, the city set dropped his ride height by 6cm - I did not need them at the time but now I need to contact him ! It's a strange thing, my 2003 td5 has boost alloys and it fits in the garage fine, but the puma has the same size alloys and tyres but does not unless i put some weight in the rear, so initially I did not think I would have a problem. it may be the td5 has a tow bar and has dropped over the years ? |
