Home > Puma (Tdci) > Bonnet security
anrw
Bonnet security
I know bonnet security has been done to death here but has anyone found the Aeroquip lockable catch a worthwhile solution?
http://www.jjcraceandrally.com/autograss/b...et-catches
Fitting neatly might be the challenge because of the bonnet edges are rounded and how good the actual locks are maybe an issue. I haven't seen any pictures of these used on a Defender - does anyone have any experience to share?
Regards
Nigel
Post #303814 31st Jan 2014 6:01pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
I am currently waiting on a Forum Sponsor to confirm they can be fitted and if so will have them done. As for how good they are, it's just another layer, if they want it they'll come prepared. But should stop the opportunist. _______________________________
Puma Defender 90
Post #303819 31st Jan 2014 6:08pm
GUM97
Never seen them before, they look interesting! An engine to TDi for!
Post #303831 31st Jan 2014 6:32pm
Romadog
Great catches. My only concern is the pegs getting in the way when leaning into the engine bay !!
Post #303854 31st Jan 2014 7:29pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
For me 2 flexo steel through the bonnet .
They may bust it , but there not taking it
Post #303861 31st Jan 2014 7:44pm
K9F
I think there would be some serious fabrication involved to get the thing fitted to the bonnet and it would have to be spot on. Not to mention the protective measures to prevent corrosion. Another layer it may be but wouldl it offer more than a flx-o-steel apart from being more obvious?
Potentially the end result could possibly look quite neat though. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #303862 31st Jan 2014 7:54pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Not on a puma but might give some ideas:
http://forums.lr4x4.com/index.php?showtopic=68685
Post #304009 1st Feb 2014 10:27am
Post #304378 2nd Feb 2014 1:40pm
anrw
Many thanks to contributors to this thread and particularly Cobs and Supacat for the link to another forum. I think it can be done neatly and without hindering day to day underbonnet access. As for the lock filling up with mud I'm sure this can be overcome. It appears a good, neat solution that adds to reducing theft risk.
I too firmly support the multi layered approach to security and why the idea of Aerocatch locks appeals. For me, the preventative measures are the most important and although the bike cable under the bonnet is likely to be effective in making it difficult to steel the bonnet, if a little inconvenient, it doesn't really form part of the 'layer'. For the multi layer idea to work the potential thief must be presented with a number of visible deterrents; LED on the dash, steering wheel lock, bonnet lock, ball bearings in the hinge bolts. pedal lock etc. A hidden bike chain under the bonnet or tracker don't contribute to the multi layer propostion because they are invisible.
On the subject of weak points and visibility. I understand, but haven't had confirmation from the agent now selling the product, that the X Eng ignition lock won't fit the current production high spec Defenders. Does anyone have a solution to this as the standard steering/ignition lock is a very weak security point.
Regards
Nigel
Post #304657 3rd Feb 2014 11:52am
K9F
anrw wrote:
On the subject of weak points and visibility. I understand, but haven't had confirmation from the agent now selling the product, that the X Eng ignition lock won't fit the current production high spec Defenders. Does anyone have a solution to this as the standard steering/ignition lock is a very weak security point. Regards Nigel
Not sure where you're getting your information from....but think the seller may be doing himself out of business perhaps unless he includes latest models in compatability? With a little fettling, adaptation, lateral thinking and ingenuity they certainly do fit....you just need to relocate the 10as transducer. I followed the instructions posted by Brian and had no bother whatsoever along with several other forum members from earlier TD5s to Pumas.
Thumbs Up
http://www.defender2.net/forum/topic17090.html?highlight=barrel If you go through life with your head in the sand....all people will see is an ar5e!!
Post #304668 3rd Feb 2014 12:32pm
anrw wrote:
...the idea of Aerocatch locks appeals.
If you go ahead with this, please keep as informed Thumbs Up
Post #304711 3rd Feb 2014 3:50pm
smb
Regards
Nigel
As what K9F has said. I fitted to a 2011 my Puma with no problem. Took about an hour all in with repositioning the Transducer being the most awkward, but you just follow the instructions. I can't imagine a 2014my being any different.
Post #304720 3rd Feb 2014 4:46pm
pjb
Ditto on Sept 2013 defender 2020 P300 HSE
Post #304922 4th Feb 2014 3:10am
