Home > Off Topic > Fence Posts - Croesote (or old engine oil)
MartinK
Someone on this forum will be able to advise me I'm sure Thumbs Up
I just got 15 4" fence posts delivered for a project. In the old days I would have bathed the lower end (the part in the ground) with real creosote, but that's no longer available.
I'll be concrete-ing the posts in.
Some people I know used to mix old engine oil with creosote. I have 10 litres of old engine oil kicking about...
So, the query is, is it worth mixing old engine oil with new products (i.e. creocote or creoseal), and does it improve things (make the posts last longer)? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #303726 31st Jan 2014 1:59pm
williamthedog
Ive always used a 50/50 mix.It seems to soak into the posts better mixed with the oil.
But beware it stays wet for a while so watch animals and kids Thumbs Up
Post #303733 31st Jan 2014 2:12pm
I thought you couldn't get creosote any more? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #303736 31st Jan 2014 2:22pm
Norm4n
You can buy a non-toxic version of the original
Post #303737 31st Jan 2014 2:25pm
MartinK
Thanks, williamthedog - I'll try a 50/50 mix Thumbs Up
Well...it's not widely available, but it can be ordered for "professional use"... Wink
I'll have to make do with Creoseal, but I'll try the 50:50 mix with engine oil Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #303738 31st Jan 2014 2:26pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
I've previously used the 50/50 mix and it the posts are short enough soak them in an old bath, weighed down. If too big put some in a 5 gallon bucket and bung the ground end of the posts in for a couple of days to let them soak it up the grain, they brush or spray the rest. A cheap 5 litre sprayer is the easy way for bulk jobs. Thumbs Up
Post #303746 31st Jan 2014 3:34pm
MartinK
Awesome. Thanks, I just nipped-out and brushed-on a 50/50 mix of Croeseal and old engine oil. Thumbs Up
Now the rain has started Crying or Very sad Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #303756 31st Jan 2014 3:46pm
geobloke
Not sure if it too late but these guys are getting quite a lot of good press with their post sleeves... Guess it depends on how long you want the posts to last...
http://www.postsaver.co.uk/
Post #303778 31st Jan 2014 4:53pm
GUM97
Anyone else love the smell of Creosote? There's about 30 litres in the garage Laughing An engine to TDi for!
Post #303835 31st Jan 2014 6:35pm
MartinK
Thanks. That looks great! well priced too - if I had seen them earlier I may have been tempted to try a few.
Yes I do Thumbs Up Probably not that healthy tho... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #303847 31st Jan 2014 6:57pm
Romadog
I use this. It soaks in quickly and does a good job.
http://www.cuprinol.co.uk/products/shed_and_fence_protector.jsp
Post #303849 31st Jan 2014 7:15pm
Kev stephenson
United Kingdom 2005 Defender 110 Td5 XS CSW Java Black
Its not the bit in the ground that usually rots, its where the water gathers on the bowl that most people make in the concrete when putting the posts in. That shrink wrap on the posts works well or put the post in a bin bag before concreting it in and make sure the concrete comes above the soil level and slopes to allow the water to run away and not puddle at the post. 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
1996 130 300TDi chip truck for tree surgery business
Post #303856 31st Jan 2014 7:31pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
If you can get hold of real creosote use that other wise creosote from wickes in dark form with engine oil mixed Smile
Stevd 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #303892 31st Jan 2014 9:34pm
rossy
A little tip :
Mix 4L Creocoat (or any creosote substitute ) with 2.5L cheap oil based brown gloss paint. It makes the most amazing looking long lasting fence paint for around the same price as those useless waterbased ones Thumbs Up
Post #304064 1st Feb 2014 1:36pm
GrahamB
Scotland 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Hi Martin, I've got real creosote at work 25litre size!
Graham 28 mpg MAX!
Post #304389 2nd Feb 2014 2:18pm
