![]() | Home > Puma (Tdci) > Whistle from Engine when cold and other issues - Advice Pls! |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
No.4: It could be a couple of things from the airbox lid not sealed correctly to a failing bearing on the accessory belt to the belt itself slipping when cold, to a leaking manifold or a leaking boost hose etc etc.. The only way to be sure is when you first start the Puma have a listen in the engine bay and try and narrow down the area the noise is coming from. Out of curiosity what dealers are you using?
| yeldef Member Since: 06 Feb 2013 Location: belgium Posts: 26 |
I,ve got nr 4 aswell, but in 3th and 4th....i'm also interested in a solution
| stewalex1984 Member Since: 06 Mar 2013 Location: Glasgow Posts: 9
Using Taggarts Glasgow, formerly Shields Landover.
Thanks for the advice, we shall see what the dealer finds tomorrow. Although I suspect I wont see my car for around 1 week with the work required. I'll post again once I have a report. Thanks, Stewart |
I got mine from Taggarts in Motherwell and although they are a good dealer (Motherwell, at least from my own experience
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
£180 to change the brake fluid
If you think it's the switch knock the brake off and just waggle the H/B lever. If you have ABS it's worth changing the fluid every year or 2,but not at £180 a time. Pov.spec,ftw. 2006, 110,TD5. |
| martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422
If its any help we have a few transits we do at work that have a whistle from cold and so far they all have loose turbos, so all you can hear is the turbo spinning up then once its warm it expands and all is ok. It might be worth checking the 4 13mm nuts / studs connecting the turbo to the cat they may be loose.
| timsmug4 Member Since: 28 Jan 2014 Location: United Kingdom Posts: 3
Point 2, how can changing the brake fluid have any affect on the hand brake?! two totally seperate systems unless ive missed sumfing!
/\/\/\ Handbrake warning light doubles as a low brake fluid/general brake fault warning light. Pov.spec,ftw. 2006, 110,TD5.
Nice 1 jimbob7 didnt know that
s111 LWB (2.25 petrol) |
| AlexSmith Member Since: 05 Sep 2013 Location: Arroio do Meio, RS Posts: 47
> 4) Since dreaded 1000mile trip 2 weeks ago, when I drive the car early morning and its cold, I get a Whistle from the engine in first and second gear at about 2000rpm. After about 30 seconds its gone. Any suggestions on what this may be?
Got exactly the same symptom. I changed the belt and all bad bearings, but the whistle at 2k/3k rpm remains, only before the engine gets warm and only on cold mornings. By looking into the engine bay and listening carefully, it seems to come from near the turbo. Not sure if it's the turbo itself... Did you find out where yours come from? 2020: Defender 110 SW 300 Tdi 2004 Alpine White 2013-2017: Defender 110 S 2.4 (Puma) 2008 Stornoway Gray 2002-2005: Defender 90 CSW 300 Tdi Dark Green |
Hello,
for the interested : the whistle came from a seal on the turbo. the following did the trick for me. https://www.nakatanenga.de/fahrzeugtechnik...turbolader grts |
What I'll say is pure speculation, but I was wondering: to me, the whistle happens on cold days only. During the summer, I never hear it. It makes a lot of sense to me that it can be a seal problem, considering metal contracts with cold. Also I notice the whistle disappears when the engine gets hot. In the end, I believe I'm having the same issue with the turbo seal. Thank you very much for sharing this. 2020: Defender 110 SW 300 Tdi 2004 Alpine White
| All times are GMT |
