![]() | Home > In Car Electronics > Courtesy Light Switches On Rear Doors |
| pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500
Use origional switched all you need is a live and a ground back to the pin 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 |
Seems like your switches are dirty or corroded. Take them out and clean the contacts and the screw hole
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Will give them a clean
So all I have to do is add the new switches and a earth wire from the switch up to the earth wire connected to the lamp? |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I'm pretty sure that the switches are triggered by a small metal tab in the leading edge of each door. If yours has never had switches fitted then it would be worth checking if those tabs are there before making a start. Darren
It has the switches fitted to the front doors but not the middle or rear, though the tabs are present
The rear door will need a tab making up though that should take all of 5 minutes. |
