Home > Maintenance & Modifications > Fitting a rear wiper relay
bear100
Hi all, I have fitted the no 99 vw relay of the front wipers Very Happy
What are the options for the rear? Just the 99? If so can someone please give me a wiring diagram I am not to sure on what connection is what on the relays
Thumbs Up Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #302942 28th Jan 2014 8:54pm
mk1collector
I remember someone put up a good guide on here a while back so it might be worth having a search for 99 relay and looking through the threads.
Post #302956 28th Jan 2014 9:21pm
K9F
https://www.defender2.net/gallery/albums/u...ations.pdf If you go through life with your head in the sand....all people will see is an ar5e!!
Post #302968 28th Jan 2014 9:34pm
I've fitted a 20 second delay relay to my rear wiper, which came as a kit that I found on eBay:
If just installed on its' own, it makes the rear wiper work intermittently. However, by adding an extra wire from the spare terminal (green wire with blue spade connector) to the back of the rear washer switch, the wiper will run continuously when the washer switch is pressed.
You could, I suppose, fit a 99 relay on the rear too, but it'd be a bit overkill and a right faff to use. Darren
Post #302989 28th Jan 2014 10:36pm
grafty99
Shocked
I couldn't disagree more! Press wiper button on/off drive along as normal, see window needs wiping again and switch wiper on and leave 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #303004 28th Jan 2014 11:01pm
theorangebandit
I need this relay for both front and rear!!!! And I keep putting off buying it!
Post #303014 28th Jan 2014 11:25pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Could you see what the part number is on the end of the relay?
Post #303020 28th Jan 2014 11:44pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Anorak Can you give the ebay details for the kit?
Post #303033 29th Jan 2014 12:34am
grafty99 wrote:
Shocked
Sorry if I shocked you Laughing Perhaps I just don't use the rear wiper enough to see the benefit.
Not without taking my rear door apart, I'm afraid Confused
It was a while ago that I bought it so I'll have to dig out the details from my home computer. Darren
Post #303065 29th Jan 2014 10:28am
Martin
Site Admin
Found this too: https://www.defender2.net/gallery/albums/u...0Wiper.pdf  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #303068 29th Jan 2014 10:38am
landybehr
when the front wiper relay is replaced by the VW type, then there is the standard relay surplus. Could be used to control the rear wiper:
http://www.landypedia.de/index.php/Defende...mbauten%29
From my very personal view, I was inclined to follow the above instructions. But before doing so I changed my mind, thinking that I drove an 88" for years with rarely missing the rear wiper, and for 1 year the 2.2 110" and occasionally using it, but never ever continuously nor in a intermittend fashion. Cannot think of my rear screen as that needs to be cleaned everey 20 sec.
I rather think the other way: I will see if I can modify the swith (for the rear wiper) in the dash so that it will not stay locked when first time pushed but instantly return the the "off" position. Itīs just like the screen wash. You only use it when you really need it. And you cannot forget to turn it off - I really hate it when the rear wiper was forgotten to be turned off and wipes and wipes ..
Post #303111 29th Jan 2014 2:56pm
bear100
Some great replies there thanks Thumbs Up
If your happy with your on and off setting then stuck with it, myself on the other hand can see a great benefit with intermittent wipe, Very Happy
I didn't think of using the surplus one from the front Embarassed great idea!
Post #303234 29th Jan 2014 9:41pm
munch90
I could count on one hand the amount of times I have used a rear wiper on any of my defenders over the 20+ years of owning them .
BUT still fancy fitting intermittent rear wiper!
WHAT IS IT ABOUT PLAYING WITH LAND ROVERS THAT MAKES US FIT GADGETS WE DON'T NEED OR PROBLEY EVER USE?
Post #303256 29th Jan 2014 10:18pm
Mo Murphy
I've used the front intermittent on the rear wiper of mine, works quite nicely Smile
50 Shades of Pennine Grey
Post #303282 29th Jan 2014 11:01pm
BarneyRubble
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I used the 99 relay to get an adjustable rear wiper.
K9f posted the wiring diagram, here are a few photos (sorry about the poor wiring).
I personally love this modification, because beforehand I was always pressing the button to get a wipe every time I wanted to look in the rear view. Now I can set it once and leave it alone.
I guess it depends upon how often you use the rear view mirror. Barney
D4 - 2016 Graphite, Montalcino Red
Written Off - 2010 90 Hard Top, Stornoway Grey
Post #303529 30th Jan 2014 8:56pm
