![]() | Home > Maintenance & Modifications > Stubborn Exhaust bolts |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
if they underneath ( not on turbo or manifold ) . like the ones that just join box to pipe etc , mine were rusted so just snapped them off then knocked the studs out and replaced with nuts and bolts
| Jim90 Member Since: 26 Jan 2014 Location: Ilkley Posts: 7
Yeah it's the three on the top of the down pipe that I'm struggling with 02 td5 pickup
better not snap them off then , what are the studs in pipe or turbo , good soaking in wd
Hopefully won't snap them studs are in the pipe I get some wd on them in the morning and give it ago when I get back from work 02 td5 pickup
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Plusgas is the number one for removing stubborn bolts,tbh, if a gas axe won't shift it nothing will. Pov.spec,ftw. 2006, 110,TD5.
Got them off with the torch no problem
