![]() | Home > Technical > Help with mystery switch |
| dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188
weird "u" shaped pipe in the rear passenger wheel arch. (tank vent ) fitted on mine to
mysterious switch under my dash, below the dials fitted mine too, but its not a mysterious |
| Benmatt912 Member Since: 05 Jan 2014 Location: Worcestershire Posts: 33
What does the switch do in yours then?
| ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831
Any sign of a beacon light having been fitted to the roof. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to Richard |
There is a flat plate at the front of the roof rack but no other obvious signs.
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Fuel tank vent pipe, might be worth considering extending it up into inside of rear of the vehicle.
Isolation switch is probably controlling power to winch. Blue switch probably controlling a now missing light bar. Brendan |
mysterious switch under my dash, below the dials fitted mine too,as i its no mysterious battery volt meter
Mystery solved. Pulled the switch out and found a white wire and a yellow wire going into it. Managed to traise the white wire, through parts of the engine bay, to the front spots on the A bar. It isolates them from the full beams.
