Home > Technical > Td5
castleton
United Kingdom 2004 Defender 110 Td5 XS CSW Stornoway Grey
Td5
My heated seats do not work on my 2004 110 defender. Any ideas? Apparently I need new heated elements which will cost £1300 for both seats to fix seat back and seat base? Big Cry
Post #301394 22nd Jan 2014 11:44pm
Laurie
Wait 'til Aldi or Lidl have heated seat covers on 'special'.
Post #301401 22nd Jan 2014 11:58pm
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
I don't have heated seats but am aware that kits available for around £90 per seat. It is a DIY fit and should cost no where near £1300 Shocked
Post #301402 22nd Jan 2014 11:59pm
Gareth
On my 2002 TD5, the drivers seat was not working. I checked for power at the plug under the base, and it had 12v so I knew it was the seat.
In the end, I traced it to the thermostat in the seat back. If you remove the seat cover from the seat back, (not too difficult) you will see a silver button thing. I just soldered a wire in its place to complete the circuit, and it all started to work.
Ok, it gets a bit hotter than it should, and when its too hot, I switch it off. Simples Cool 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #301403 23rd Jan 2014 12:03am
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
You could always get a Waeco heated seat kit and just replace the pads in the seats. The kit comes with all wiring and switches but you wouldn't need to use them. If you want to use the same type of connectors that are on your existing pads you will either have to find new ones or alternatively cut the old ones off and join them to the wiring on the new pads.
Simon at MPS Trading (a site sponsor) does the kits for 2 seats. Go here: http://bit.ly/1cojrZl
Genuine LR seat pads are a lot more expensive but should have the connectors on already. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #301409 23rd Jan 2014 12:17am
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Having just bought a Waeco kit from MPS via eBay ( terrific service from them) I can tell you the waeco kit has two heat settings, which you won't be able to take advantage of with OEM switches, but no reason you can't wire your switches to the high setting alone.
You need to fit the pads into the seats which is easy. There are Youtube videos of how to do it. I found out after. Took about an hour to do two front seats, including taking them out and putting them back, which may not even have been necessary.
Kit from MPS was £50 delivered I think so even if you got the Queen's auto electrician to fit them, you'd stilll be ahead of the game. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #301417 23rd Jan 2014 6:05am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
You can buy the Landrover pads here for single seats or pairs.
Single seat
http://www.lrisolutions.co.uk/index.php/la...0-110.html
Pair of seats
http://www.lrisolutions.co.uk/index.php/pa...0-110.html
Post #301427 23rd Jan 2014 9:18am
Macpaul
Oh rats. Nice find.
Hey ho..... 2003 Td5 110 Hardtop
Post #301431 23rd Jan 2014 9:33am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Wow for £1300 you could have a brand new set of Exmoor Trim premium seats with heaters. In fact you can get a set of new half leather XS heard seats for half that on eBay. Plus you could probably get a couple of hundred for you old seats if you sold them on too...
Post #301492 23rd Jan 2014 2:02pm
castleton
Single seat
Pair of seats
Thanks very much for the heads up on what seems to be an excellent site
Post #301498 23rd Jan 2014 2:32pm
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
I would recommend the Waeco elements from Simon at MPS, installed mine two years ago, work a treat and you get a very toastie back side, £50 two seats very good value
Post #301558 23rd Jan 2014 6:30pm
castleton
castleton wrote:
Single seat
Pair of seats
I visited the co yesterday. The guys replaced my heated elements in both seats for £204 incl vat some £1100 less than the LR dealers wanted.
Great service from this co who know our trucks inside out.
Highly recommend them.
Many thanks.
Post #304272 2nd Feb 2014 12:04am
