![]() | Home > Technical > EGR removal on mapped td5 |
You'll have to try it and see. Prior to my current map I had an Autologic one that was fine. After several modifications later the vehicle would overboost in certain circumstances.
Without knowing which one you've got and contacting the originator as mentioned you'll have to suck it and see. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 372 ![]() ![]() ![]() |
Mmmm thought that might be the case!
I'll have to have a think as to wether its worth it. Cheers mate. ![]() |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 861 ![]() ![]() ![]() |
Get rid of the EGR, one of the cheapest mods you can do to improve your TD5
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 ![]() ![]() |
Agree with Eddie, that and a decat pipe make them totally different to drive!
...and don't forget centre box removal and airbox mod
Those are exactly the modifications that 'threw' my map out of tolerances and caused overboosting. Spoke to the forum bespoke tuners and ended up with something that was more than capable to take these modifications into account.
![]() Treat every day as if it is your last....one day you will be right!! |
Cheers Guys,
It was already decated with straight through exhaust ..... You got to love the sound. Not sure what air box mod is, I'll have a search. Cheers 2006 Defender Double Cab- Zambezi Silver |
