Home > Wheels & Tyres > Black Wheel Nuts
Page 2 of 2 <12
xatzhs
Great looking vehicle mate! Thumbs Up
What size tyres are those?
Post #144998 14th May 2012 9:24pm
scottish110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Thanks...
265/75/16 AT's with 30mm spacers
Post #145055 15th May 2012 9:58am
Zagato
If ordering POR-15 make sure you get the UV protected type Shocked Thumbs Up The original POR -15 was made for axles/chassis etc so didn't need to be UV protected.
Post #145068 15th May 2012 10:51am
danridge
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
Is it possible to get black wheel nut covers for alloys?
Seem to be plenty available for steels but cant find anything for Alloys. Similar situation to this thread, I'm having wheels powder coated black and want to make the alloys nuts black too.
Post #299634 17th Jan 2014 4:23pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Get the nuts coated at the same time?
Or just paint them black? - easier to restore after damage when taking off/doing up
Post #299644 17th Jan 2014 4:55pm
K9F
http://www.wrington.co.uk/landrover%20alloy%20wheel%20nuts.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #299653 17th Jan 2014 5:24pm
danridge
£200!! Shocked
Post #299657 17th Jan 2014 5:33pm
K9F
£190 I make it! I gather from that a pot of paint it'll be then! Laughing
There's obviously a lot more engineering required to make alloy wheel nuts than steel.
I bought the hand polished stainless ones but knock off the locking ones on each wheel (if you fit them) and you obviously reduce the price. He also threw in enough spares for me to do the spare on the rear for free.
Then again the stainless ones are cheaper for steel wheels. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #299663 17th Jan 2014 5:38pm
danridge
This would be ideal but I need the truck on the road whilst this is being done so have dropped the spare wheel of and will rotate them one a time. I don't have a spare set of nuts to get the nuts done at the same time as the wheels Sad
So painting them in situ on the truck or plastic caps looks likely.
If anyone has a full set thru want powder coated black I'll pay for the powered coating in return for a loan of full set so I can get mine done too and keep the truck on the road Thumbs Up
Post #299664 17th Jan 2014 5:39pm
danridge
There are lovely but I kind of forget to factor nuts in the spend so yes will be paint I reckon Laughing
Post #299682 17th Jan 2014 6:49pm
Likeomg
plasti dip.... can't fault it, used it for 6 months now, about £8 a can just dip it in, leave it a few hours to dry and then bolt back up
Post #299697 17th Jan 2014 7:05pm
danridge
Thumbs Up Is that different to Plasticote? As I've bought a spray can of that to spray the plastic wheel centers
Post #299726 17th Jan 2014 8:51pm
Likeomg
I think it's very similar, I plasti dipped the steering guard which looks great, lasted well too, I use the like tin of plasti dip on the wheel nuts
Post #299732 17th Jan 2014 9:00pm
danridge
Did the plasti dip stand up to the nuts going back, tight, without damaging the coat?
When you dip them doesnt it dry with a drip shape? how did you do yours?
Will a 250ml tin do all 20 nuts? and did you use metal primer first?
Thanks Thumbs Up
Post #299772 17th Jan 2014 10:52pm
Page 2 of 2 <12
