![]() | Home > Maintenance & Modifications > I now have brilliant lights! |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288 ![]() ![]() ![]() |
I am truly amazed!
I have just fitted this http://www.devon4x4.com/index.php?page=sho...;Itemid=14 to the Defender. Full beam is now like night sun! Nice bit of kit - well done Devon 4X4. Mark. |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Mate for £750, I would expect nothing less
Ragerover Member Since: 27 Dec 2013 Location: In a land far far away Posts: 145 ![]() ![]() |
£750 yikes
alfajock Member Since: 12 Jan 2011 Location: Bedfordshire Posts: 227 ![]() ![]() ![]() |
Nice, I've been eyeing them up myself. Expensive, but the lights themselves retail at £280 each so the extra £190 for the bumper, with the lights already fitted and properly finished seems reasonable to me.
What I'm undecided on is; a. the wisdom of putting expensive light units in a bumper, and b. Whether for similar money full led headlamps ( Speaker / Nolden etc) wouldn't be a better bet as dipped beam should be improved too. They do look great though! Fully Restored 89 110 CSW V8 CLS 350 CDI for the sensible stuff |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
For that price, I'd want a following Helicopter lighting the way!
![]() Must see some photos though! ![]() 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
The Lazer Lamps are a brilliant bit of kit
![]() We have two Lazer ST4's fitted to our black 110. These are the non DRL version of the RS4. Yes they are great lights. Both versions are E marked and road legal if wired through the main beam switch. If fitting good quality LED optional driving lights then there is a problem when going back to dip beam of standard Land Rover candles as they would appear even worse then normal going from main to dip on standard candles as the difference is so much greater. Alfajock
a) If the lights are mounted inside the bumper then they are slightly more secure then mounted on top of the bumper. It is much more difficult to angle the lights to get better sideways lighting. If mounted on top of the bumper yes slightly more exposed to the scumbags, so use different security fittings. Can be angled slightly outwards for a better spread of light b) Good quality LED headlights do not come cheap and there are various makes available. Check the following 1) Are they type approved, i.e. E mark? If they are NOT E marked they are ILLEGAL. Some sellers claim they will pass a UK MOT which they may or may not do, however they will still be illegal. 2) Actual light output, most makers will give you a calculated potential light output under perfect conditions, this is a headline figure or raw lumens. Next, but lower figure is the calculated effective lumens. This is the calculated raw lumen figure minus the calculated anticipated losses. Some makers actually give a measured light output which is the real figure to be interested in. If only one light output figure is given then it will be the headline raw lumen figure, which assumes everything is working perfectly, top quality with absolutely no losses. 3) IP rating. IP67 is the minimum acceptable. The best IP rating is IP6k9K which is a German rating and says that the light unit can be jet washed 4) Looks. That is down to personal taste 5) Budget Brendan |
