![]() | Home > Puma (Tdci) > How to remove ECU on 2.2 Puma |
| SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464
Hello,
Just called BAS and I am now tempted to have my ECU remapped for more power and remove the limiter. Any tutorial on how to remove the ECU as I want it shipped to the UK 2016 Defender 90 Adventure Edition |
Managed to get it out, already at Fedex in transit to BAS for a remap 2016 Defender 90 Adventure Edition
| pascal Member Since: 24 Nov 2013 Location: Nicosia Posts: 21
how did you remove it, need help to remove mine too...
thnx |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Two bolts hold the sound deadening cover on the top front of engine, remove and then lift cover off.
The ECU is at the rear on bulkhead. Pull, carefully, the two plastic cable holders that look like they are nuts, this reveals two actual nuts that hold the ECU in place - remove the nuts. The ECU has three connectors on the left hand side, carefully disconnect and then lift the ECU out |
| All times are GMT |
