![]() | Home > Td5 > New Key |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
Just change the door lock barrels for a new set ? Probably much cheaper than a locksmith.
Assuming you have the early door locks where the ignition key and door keys are different a new set of 3 or 5 barrels with keys can be bought new for under 20 quid. When I bought a 5 barrel set each barrel came with a key (all the same as they were in a set) ! I had more spare keys than I knew what to do with ![]() You could also change over to the later style barrels which is a more expensive option but you end up with a new ignition barrel and a set of door barrels, complete with new keys. the ignition key is then used for the doors too and is potentially marginally more secure. To use these on older Defenders will require replacement door handles and a replacement rear door lock mechanism so it's not a cheap option - think it cost me around £200 all in when I converted Pam's 90. You have to replace the handles and rear door lock because the newer barrels are longer and wider. http://www.yorkshireoffroadclub.net/ |
Hi Tom. If you have a TD5 then the ignition key is the door lock key as well. Is on mine anyway, 2002 TD5. Well it would do if some scroat hadn't stuck a screwdriver in the drivers door last year. Still opens the rear door though. |
Little Tom Member Since: 20 Aug 2013 Location: Lancashire Posts: 134 ![]() ![]() ![]() |
Thanks to you both for replies
![]() It hasnt bothered me too much as I have the remote but as time goes on I know im heading for trouble if I dont have a back up to the door remote. Looks like those replcament locks might be the answer unless anyone else can convince me to persist with the WD40 option? Tom Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert.. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
If the lock barrel has siezed up it may take a lot of work (and WD40) to get any motion. When I bought my Puma, the previous owner hadn't used the key lock on the door for at least a year, possibly 3, and the key wouldn't go in. It took me about an hour of work with WD40 and the key to get some life back into it, but it did free off in the end. I now make sure that I use the key in the lock every now and again to make sure it doesn't seize. Just be careful not to apply excess force to the key when turning (I seem to remember that I did have to tap the key to get it all the way into the lock to start with).
I bought a complete keyed alike genuine steering lock assembly and drivers door lock barrel of Ebay at the time fo a very modest price - something like £25 IIRC - although I didn't actually need it in the end. |
Charlie Spitfire Member Since: 16 May 2015 Location: Chartres Posts: 55 ![]() ![]() ![]() |
Hmmm, this is interesting. I have been spraying releasing oil into my seized door lock for over week now and nothing gives. I have beeen a little bit nervous about forcing it with my ignition key to free it up. I take it then with patience and persistance it can be done with
Yes, lots of patience and persistence as the locks probably have never been used due to central locking but they should free up eventually. Ray
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 335 ![]() ![]() ![]() |
This is interesting - my 2002 TD5 won't open by key on the passenger side, but works fine with the remote. The ign key works OK for the drivers and rear door though! I'd better go and stock up on WD40!!! |
Would some proper graphite made for locks be better than wd40?
I'd use wd to get it moving then tonnes of brake cleaner in to degrease then leave to dry then add graphite powder Ray
Hmm WD40 hasn't done much so far! It feels like it is the wrong key - just won't move!!
So I squirted in releasing oil once a day for ten days and now the key goes in all the way. The lock doesn't turn though. I will keep squirting and gently turning and I will let you know.
Still squirting oil into it, still can't turn the lock
Grey110 Member Since: 20 Jun 2012 Location: Delft Posts: 35 ![]() ![]() |
Sounds like an over sensitive anti theft mechanism. Did you try to reboot?
![]() Previous 2003 Defender 110 Hardtop TD5 2004 Defender 110 Station Wagon TD5 - Libyan Sand 2005 Discovery 3 - V8 - Black |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Good point, I don't think I've used the manual locks at all in 5 years! ![]() I do now at least have three keys, one original Leyland type. ![]() |
