Home > Puma (Tdci) > orange drops in passenger foot well..
Page 2 of 3 <123>
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Far too much water for condensation and only happens after a downpour when stationary.
Post #28619 31st Mar 2010 4:06pm
Grockle
mse wrote:
As for the internal gutter dripping water - this has been a feature (or issue) of defenders since the dawn of time. The water most of the time is condensation apparently
if thats the case then a small person could drowned and be seen floating just above window level,in fact I think the 107" in Chaucers, 'A Canterbury Tale' leaked in that very place Mike 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #28621 31st Mar 2010 4:15pm
K9F
Water Getting In?
Water getting in????
Numerous threads on the same/similar theme Grockle posted an excellent pdf route down which to travel some time ago (can be accessed by my second post on the thread link below) ... have a look and see if any of the links in this thread may enlighten/assist you:-
http://www.defender2.net/forum/topic2943.html?highlight=
Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #28622 31st Mar 2010 4:18pm
mse
The V8 always used to do it...it used to be a joke about getting wetter on the inside 90/110/defender drivers used to make, im surprised no one remembers Exclamation
There could have been other leak causes, but its a problem thats been around for the last 20yrs - almost as long as the water ingress pdf Rolling with laughter Mike
Post #28636 31st Mar 2010 6:45pm
RED-DOT
Mine leaked like a sieve since new and the passenger footwell still leaks... My suppliers bodyshop manager quoted that the worst thing LR ever did was put carpets in the Defender as water used to leaked out as fast as it came in... Emm, No, not on a £25,000 car? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #28657 31st Mar 2010 9:50pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Mine is fixed now so i've got a wet suit and snorkle for sale if your interested worked for me Whistle Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #28661 31st Mar 2010 10:13pm
Laurie
Keep 'em for next week Rolling Eyes
Post #28672 31st Mar 2010 10:39pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
You can see their point though (price aside). I can't really take mine wading because it'll leak (as they all do) and I'll then spend 2 weeks trying to dry the carpets out Big Cry
Obviously for what I use it for, carpets, soundproofing etc and more important but I am slightly handcuffed in what I can really do with it as a result. Thumbs Up One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #28674 31st Mar 2010 11:28pm
bob neville
Grockle
I don't want to panic you but ...........
Mine went in on Monday to have the heater box sealed should have been back today. The dealer was worried that the foam seal under the windscreen was shot but we could not get water to come into the cab via that route so everybody concluded the heater box needed to come out and be resealed.
I phoned this afternoon and I now have a topless double cab Shocked
On Monday I pointed out that the small gutter under the trim was rusty on the passenger side. When they took the dash out to fix a wiper problem they found a lot of corrosion/rust that needed to be repaired behind the dash. When the vehicle went to the body shop they found that water was pouring through the foam seal under the windscreen under certain conditions. They took it upon themselves to remove the roof and fix the problem. If it is not back by Friday I will be offroading at the weekend in the dealers nice shiny new demonstrator - it won't be shiney for long Laughing
This is the second or third Defender that they have had the same problem with so it may be a common problem. Yeovil LR are now of the opinion that defenders should not leak into the footwells so try their utmost to rectify the problems correctly.
You have been warned !
Bob
Post #29834 14th Apr 2010 7:30pm
Grockle
thanks Bob,it's never done it since,I'll have it to bits to check for signs of rust 2.4 90 XS
Post #29864 15th Apr 2010 9:29am
bob neville
Grockle
Mine does not leak all the time. For the first six months there was never any sign of water then just after christmas it started to leak and then stopped again in february.
It only ever leaks when the vehicle has been parked and there has been heavy,constant rain. The dealers theory is that the rain cascades out of the gutter under the screen and wicks into the foam seal, probably where the false screen hinges are, and depending on the amount of rain fall the water leaks inside or not as the case may be.
Bob
Post #29865 15th Apr 2010 9:36am
Bosun
I have a similar problem, with some heavy rust evident in a supporting channel for the dashboard, visible from the passenger footwell area. My concern is, how much more rust is there behind the dash, or anywhere else for that matter, thats going to rear it's ugly head after the warranty has expired!!! Please, none of the "it's a Land Rover, what do you expect comments", thats not the point. They are new vehicles that we have all paid good money for.
Post #29909 15th Apr 2010 6:42pm
fekete
Mines in on the 27th for the same thing there taking the dash out to examine it... L/R are going to rectify the problem ...Don't worry about when your warranty runs out you have six years for rust...I'll keep you all updated Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #29910 15th Apr 2010 6:46pm
mse
Although mine was the air box, i had a quick look and couldnt see anything.
Are there any good areas to review without removing the dash?
I looked around the dash down (behind soundproofing and caprets) Mike
Post #29913 15th Apr 2010 7:23pm
fekete
Mike this is a shot of under the drivers side of the dash hope this helps Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #29917 15th Apr 2010 8:31pm
Page 2 of 3 <123>
