Home > Td5 > td5 defender 1999 running issues
kevin1
England 1999 Defender 90 Td5 SW Rutland Red
hello got a problem that is weird .starts first turn every time and settles into smooth tickover,if i then drive till the engine is at temp all is fine.issue shows if i only do a couple of miles then stop for an hour or so when i drive away it starts and runs smooth pulls away then within 100yards will not pull engine is smooth but no power ,if you floor the accelerator it takes an age for the revs to build up then at a certain point up the revs it takes off like a scalded cat change gear then wait for the revs to builds.this happens for a few minutes then clears and is fine.i fitted a new maf changed fuel filter and cleaned out pump with no effect any help much appreciated
Post #298428 13th Jan 2014 8:13pm
bob neville
Couple of easy checks you can do.
Pull the red plug on the ecu and check for oil.
Check the turbo actuator rod to make sure it is not sticking.
2013 Defender 90 CSW - sold
Post #298432 13th Jan 2014 8:19pm
kevin1
thanks for the quick reply i have checked the plugs and no sign of oil the waste gate i have disconneccted and is nice and free then reved engine and watched the waste gate open and close
Post #298445 13th Jan 2014 8:38pm
bob neville
Are you getting any blue smoke at all - sounds a bit like a build up of something in the pots and taking a while to clear ?
Post #298452 13th Jan 2014 8:46pm
kevin1
bit of black smoke when cold and you boot it but when it plays up nothing until the revs build then when it takes off big tube of black smoke until you change gear and the revs drop then as soon as the problem clears no smoke no matter how you drive
Post #298463 13th Jan 2014 9:21pm
bob neville
Black smoke is normally incomplete combustion in a diesel.
It could be a multitude of things but an easy place to start is the air filter - make sure it is clean and has not got wet. Also may be worth disconnecting the MAF (I know you have fitted a new one but ...) and seeing if the problem goes away. Was it a genuine MAF, aftermarket ones are known to sometimes cause problems.
Then you are looking at things like the fuel pressure regulator, injectors and injector seals.
Also, have a search for a recent post by JWL about the trap/filter on top of the fuel pump.
Post #298476 13th Jan 2014 9:50pm
landy andy
Think your MAF has failed, unplug the MAF and try.
Andy
Post #298478 13th Jan 2014 9:59pm
kevin1
thanks for that i bought a pattern maf never again genuine now much smoother will look at filters and iwas wondering about seals and temp wether the slight warm then cool has an effect
Post #298483 13th Jan 2014 10:02pm
landy andy
Sorry, but are you saying that you have already changed the MAF? And you still have the problem? Have you driven with it disconnected?
Andy
Post #298489 13th Jan 2014 10:04pm
kevin1
tryed a pattern maf ran horrible disconnected drove it for a couple of weeks drove better but smoked a bit on acceleration(handy when overtaking cyclists that think they own the road)still had the power loss,fitted genuine maf runs sweet but still has has this odd power loss which never happens once the temp gauge gets above the blue section and not every day,can do exactly the same journey strat stop start and it will only do it every second or third day
Post #298498 13th Jan 2014 10:28pm
bob neville
Might also be worth taking the MAP sensor out of the inlet manifold and giving it a good clean with contact cleaner.
They do get dirty.
Have you still got the EGR or is it blanked ?
Post #298504 13th Jan 2014 10:39pm
kevin1
cleaned map sensor and blanked egr thanks
Post #298505 13th Jan 2014 10:41pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
Check that the turbo hose has not delaminated. It doesn't sound 100% to match your symptoms but easy enough to take one end off and feel inside.
This was a problem on our 2000
Cc
Post #298593 14th Jan 2014 8:33am
