Home > Maintenance & Modifications > Water ingress in footwell
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I have the age old problem of drips of water coming into the footwells following a downpour. I have Tigersealed the screen to bulkhead seal and am happy that water is not entering here. I have read that pedal boxes and cables allow water to track into the car and rather than removing the pedal boxes I was wondering if anyone knew of a spray applied, waterproof sealant that dries hard so I can give the top of the pedal boxs a good spray?
Post #297853 11th Jan 2014 7:27pm
landy andy
Could you use a cavity wax,
Andy
Post #297863 11th Jan 2014 7:47pm
borderterrier
Thought about that but I would prefer something that dries to a skin
Post #297894 11th Jan 2014 8:34pm
rossy
I've got the same issue and when we get some dry weather I'm going to drench everything with Captain Tolleys Creeping Crack sealant. It just follows the same route as rainwater and then solidifies into a flexible barrier. Many guys here have recommended it and you can get a large bottle from Amazon quite cheap
Post #297902 11th Jan 2014 8:46pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #297905 11th Jan 2014 8:56pm
borderterrier
Cheers fellas Very Happy
Post #297916 11th Jan 2014 9:17pm
landy andy
All depends how big hole is. Creeping stuff is really really thin, so will only fill tiny holes. Where as the Dintrinol cavity wax that I'm using at the mo is thin from can, but sets thick when it dries, and remains flexible.
Andy
Post #297923 11th Jan 2014 9:31pm
ZeDefender
You said you did frame to bulkhead - I suppose you did all around the rubber screen seal itself? Tell someone you love them today because life is short.
Post #297925 11th Jan 2014 9:35pm
borderterrier
Windscreen fitter in Paderborn did when he replaced my cracked screen. An excellent job in fact
Post #297927 11th Jan 2014 9:42pm
ZeDefender
Well, apart from double-checking (apologies to your fitter) there is no water on the sill above the bulkhead seal (just stuffing rolled up kitchen roll along there works) another common leak is around the door seals.
In order to test these things (done a few of my mates' defs too), I cover each "suspect" area (screen rubber, bulkhead seal, door surrounds) with duck tape or butyl tape (you need a lot for the doors) and then use a hose pipe to simulate the worst conditions. Never had a leak lower down (pedal box) yet though.
Always worked so far and LR just fitted a new frame for me after I proved they (!) had a problem Wink
Matt
p.s. did you ever get that fine? Tell someone you love them today because life is short.
Post #297930 11th Jan 2014 9:53pm
borderterrier
I did yes, €35!
Post #297947 11th Jan 2014 10:19pm
ZeDefender
Wow - that was lucky... or skilful, if you look at it that way Laughing Tell someone you love them today because life is short.
Post #297971 11th Jan 2014 11:40pm
borderterrier
For very small cracks has anyone had experience with Capt Tolley's stuff at all? Thinking about sealing trim on caravan as a preventative measure.
Post #298048 12th Jan 2014 12:42pm
landy andy
Yes have used it a few times and is good stuff on little gaps. Used it on boats, and the defender. Worked well on my td5 windscreen.
Andy
Post #298057 12th Jan 2014 1:21pm
