Home > Maintenance & Modifications > Home-made LED halo headlights
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I bought a set of LED halo headlights from Bolt on Bits for my old 90 and was quite pleased with them as the gave the truck a bit of bling and looked pretty good. I know it's a matter if taste but DRL's as an integral component of the headlight look a bit more factory in my opinion.
Anyway, I thought I'd do the same for my 110. I couldn't find what I wanted from BoB and to be honest I didn't fancy paying another £100 or so for a pair of halos. I looked at other types but they weren't what I wanted either. So, a bit of searching on eBay to find the right type of LED strips and a set of crystal headlamps from Simon at MPS (top man) and I had the components for the project.
So the next question was how to get the LEDs in the headlights? Only two options, use the existing hole for the bulb or stick the headlamps in the oven to bake and then try to separate the two halves. I opted for the first option and fed the LEDs through the hole after feeding the wire through the existing small hole in the headlamp bowl.
As it happens, the length of the LED strip is more or less the same as the internal circumference of the headlamp lens, I trimmed around 3mm of the end of the soft plastic that houses the LEDs making sure to leave the internal copper rails with sufficient insulation. Next step was to align the point at which the two ends meet with the small hole at the top of the headlamp bowl to keep the wire nice and tidy. Now it's a bit fiddly trying to work through the bulb hole but with a bit of patience the LED strip can be pushed into place. I used the handle of a wooden spoon as this shouldn't scratch the reflector. Once the strip was in place it was just a case of making the two ends sit nearly together. There was a slight overlap but this is a good thing as it is possible to use a bit of pressure to squeeze the end in to make a press fit. I didn't use any adhesive to keep the strips in place as once there are in the final position they cannot move as they are wedged in tight. This is also handy if they need to be replaced at any time, no adhesive to remove Thumbs Up
So that's it really, all done in around 30 minutes. All that remains is to put a bit of tape over the cable exit hole, wire them up and fit the headlamps. I'm very pleased with the result and just how easy it was. The best bit is that it cost less than half what BoB charged for the same thing Smile I'll post up a pic of them lit up once I've fitted them to the 110. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #297194 9th Jan 2014 2:59pm
MartinK
Nice neat Job, very impressive Thumbs Up
It'll look pretty good I'm sure.
Some (IMHO) Audi's and Korean cars have gone mad with DRL/LED configurations...some of them look more like mobile Christmas trees than cars Confused
However I think the ones in the new Range Rovers look good Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #297197 9th Jan 2014 3:20pm
Tiger
Like it
Lets see a photo fitted
Post #297201 9th Jan 2014 3:54pm
Brite Light LEDs
Looks great Cool
Post #297381 10th Jan 2014 12:16am
rustandoil
Nice job Bow down
Somehow i kept thinking "ship in a bottle" Very Happy
Post #297405 10th Jan 2014 7:14am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
any pictures of fitted item? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #297413 10th Jan 2014 8:31am
rustyboxx
Hopefully, I'll get them fitted tomorrow and post up pics then. 2015 90 XS CSW TDCi - Beautiful
Post #297414 10th Jan 2014 8:38am
rustyboxx
Got round to fitting the headlights today along with a pair of Osram Nightbreaker 110% bulbs. Much better than the standard LR fitment Smile
I'm chuffed with the LEDs and think they match the LED sidelights quite well. 2015 90 XS CSW TDCi - Beautiful
Post #298127 12th Jan 2014 6:37pm
GUM97
They look top notch Thumbs Up An engine to TDi for!
Post #298135 12th Jan 2014 6:48pm
rustandoil
That looks fantastic Bow down too bling for my Defender, but will use on my Mini Mr. Green
Post #298147 12th Jan 2014 7:37pm
Very nice mate, well thought of and works well. Thumbs Up That offer of popping by still stands you know. Whistle ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #298151 12th Jan 2014 7:50pm
Dave T
Do you have a link to the eBay LEDs 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #298195 12th Jan 2014 9:41pm
rustyboxx
Just checked eBay and there's loads of listings, go for a UK seller though. If you search for '48 white led strip' that should pull up all the relevant items. Alternatively, the seller I bought mine from is mota-kraft. Usual caveat applies, I'm not endorsing nor am I connected in any way with the seller. Thumbs Up 2015 90 XS CSW TDCi - Beautiful
Post #298218 12th Jan 2014 10:44pm
steveyorks
England 1993 Defender 90 200 Tdi CSW Barolo Black
Are you a gynecologist by trade by any chance?
Post #307864 13th Feb 2014 9:01pm
Mean Green
Where did you get the side lights and indicators? BoB??
Post #307898 13th Feb 2014 10:13pm
