![]() | Home > Maintenance & Modifications > Replacing front suspension |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
As I am planning on fitting a winch and bumper on my 110 I know that the front standard springs won't be up to the job, the front is already sitting much lower than the rear which I think is normal for the CSW.
Question is, can I just fit a pair of longer heavy duty springs and shockers to the front or do I need to do the rears too? Only looking at a 1.5" lift but the back looks high enough as it is. Andy |
Half a Job Andy
Will replace all 4 if req. just wondered if it was necessary
Andy only did the front on mine 1" thou and level her out but mine has OEM HD springs at the rear
Are the HD rears the ones with another spring inside the main spring? Andy
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
NOT REALLY. HD REAR SPRINGS ARE JUST STIFFER. YOU CAN SET UP THE INNER ONES AS WELL. Puma 110" SW
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Ahem, Who fitted the front ones Ken ![]() |
Alex e Member Since: 23 Apr 2007 Location: Home isn't it Posts: 204 ![]() ![]() ![]() |
one of his workshop numpties i expect, or you........
