Home > Off Topic > Garage walls
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Garage walls
I've recently moved into a 50 year old house with garage largely untouched since built. The bricks have been painted white at some time in the distant past. Being the age it is the garage is narrow and an extremely tight fit for most modern cars (sorry, the Defender lives outside).
Would you:
1. Wire brush off the flaky paint and then paint over with a good quality exterior wall paint (I've used Sandtex in the past and been pleased with the results).
2. As above but use a high build or textured surface paint-like material (I've not used before and am c**p at getting a smooth surface with a float trowel).
3. Dry line and skim (and given my float trowel skill deficit that means paying someone to do the job).
1. and 2. keep the width but present a hard surface to opening car door edges while 3. presents a softer surface to the car door but reduces the width of the garage slightly.
Any/all suggestions gratefully received, especially ideas other than 1. to 3. above.
Rob
Post #296904 8th Jan 2014 4:23pm
Leenorthants
carpet on the walls where the doors touch, simple, cheap and effective!
Post #296913 8th Jan 2014 4:41pm
leeds
Go for 1 Thumbs Up
For 3 you used to be able to get rubber bumper for door edges. Or consider something like an old 10mm foam sleeping mat/neoprene rubber fixed to the wall to protect door edges. A lot cheaper and quicker then dry lining.
Brendan
Post #296916 8th Jan 2014 4:43pm
Laurie
Leave the car outside.
Turn it into a workshop/bolthole.
Cover walls with posters of half naked young ladies.
PS Don't forget the beer. Rolling Eyes
Post #296917 8th Jan 2014 4:43pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
clean it
leave existing paint on walls but scrub off loose bits
carpet on wall where doors open
keep defender outside
use garage as a work room and when necessary for repairs BM52
Post #296922 8th Jan 2014 4:59pm
Romadog
Don't think I need to comment as those above have answered it well for you Thumbs Up
Post #297015 8th Jan 2014 8:46pm
jimbob7
Insulate it,wood burner in the corner, cheapo wood laminate floor, old leather sofa,TV,fridge =MANCAVE!
(not forgetting workbench and tools). Thumbs Up Pov.spec,ftw. 2006, 110,TD5.
Post #297024 8th Jan 2014 9:19pm
AndyS
What do you want to do with the garage when it's done?
If it's to store a car then it just has to be dry and airy, it you just want to have it looking good then the wire brush/paint will be fine. If it's something more detailed then you're into rendering the walls and plastering over it. It all depends where you want to end up.
Post #297040 8th Jan 2014 10:13pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
“present a hard surface to opening car door edges”
So? A bit of paint on a door edge may/may not be scraped off? A touch-up brush will work out cheaper than dry-lining, skimming, skirting boards, painting etc.
Whitewash the walls and a couple of strategically placed carpet tiles, job done…
Peter
Post #297047 8th Jan 2014 10:26pm
defender4
Thanks all, the balance of opinion is clear.
It'll be the cheap option then, scrape and paint - and I've got plenty of bits of carpet underlay, so that's car door protection dealt with as well.
Rob
Post #297159 9th Jan 2014 11:07am
MartinK
Can you use a compresor & spray gun to apply masonry paint? It'll speed up the process a lot? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #297160 9th Jan 2014 11:33am
defender4
Good thought Martin, I had considered spraying but then there's always the cost of hiring equipment etc. and since I am retired, time and speed are not of the essence.
Post #297161 9th Jan 2014 11:38am
