![]() | Home > For Sale & Wanted > [Free] LED bulbs |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Hi, these may fit my light, can I take them?
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5951 ![]() ![]() ![]() |
If you want them grab them unless you want to measure up first? 1999 Defender TD5 110
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Second dibs please
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20793 ![]() ![]() |
Those should be good.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Ok. Dibs accepted. 1999 Defender TD5 110
They will fit, happy days, cheers |
Great. PM me your address and will post them out. 1999 Defender TD5 110
It's generally 42mm for interior lights, you could allways try dropping a blob of solder on each end to make up the difference.
Above is correct but. Have 38/39mm in mine, a little smaller but the contacts can be bent a touch closer together yo egg a perfect fit.
Any smaller though and it's impossible. The standard bulbs generate quite a bit of heat, draw a decent amount and can flatten the battery quickly if not careful. Especially if there is two! I've got all of my LEDs and the lot put together even two fixtures and all the rest of it put together only use about 0.5A - 0.8A And about only 50mA for the rear just the light only, that's just 0.050A ![]() So both sandbars bulbs were pulling about 2 - 2.2 A (estimated) Now both pull around 0.8A combined. If you only had LED fixtures such as these then the draw plummets and is about 0.2A which is nothing really. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
That's why these LEDs are on the 'Free' list cost they didn't fit!
![]() Regards John M0VAZ Econet Station 48 no clock |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2059 ![]() ![]() |
If these didn't go I'll have them.
Still waiting on a PM from Leenorthants for conformation of wanting the lights. 1999 Defender TD5 110
Taken - thanks for the interest.
john 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Posted. 1999 Defender TD5 110
