![]() | Home > Puma (Tdci) > 2010 defrender keeps dying |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052 ![]() ![]() |
Check battery conections.
Andy |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
And give it a good charge up.unless of course you have been doing that. All those start ups will have taken their toll on the battery unless you either charge it up or have been on a good run.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18034 ![]() ![]() ![]() |
Also check the main and starter relays under the driver's seat are tight in their sockets. Loose relays or poor connections can cause these symptoms.
CsD1970 Member Since: 06 Jan 2014 Location: essex Posts: 2 ![]() ![]() ![]() |
It was a low battery and loose connection, thanks. Now the EM light has come on the way back from work tonight, but I haven't lost any power in the engine and it is running fine, I don't understand it. I'll check the oil and water levels tomorrow in the daylight.
