Mean Green
| Lubricating Gliderol garage door?? | |
Does anyone have a gliderol roller door on their garage/workshop?
I fitted mine about 8 years ago, for the last couple of years it has been giving a loud grinding squeak when it is going up and down which sounds like the spring is dry. I am sure a couple of squirts of lube would do the trick, but I have no idea how I might get it to the spring. I do not fancy monkeying around with the tensioned spring with no idea what I am doing.
Has anyone managed to lubricate the spring?
Now and then it judders badly in the tracks - according to gliderol you should not use any oils or lubricants on the tracks. However I have been so fed up with it jamming I gave it a squirt of spray grease and it is now gliding up and down with no judders and veyr little noise (other than the spring as above).
6th Jan 2014 9:00pm |
marsie
On my garage door the tracks are steel but the door has a canvas type strip where it fits in the channel. In the bumph that came with it, it says not to use oil or grease but instead use furniture polish
I give mine a good squirt with pledge once a year and that seems to work fine . Also if you use the lemon variety it smells nice too
Paul 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
2004 110 TD5 Double cab. *GONE*
2010 110 2.4 XS station wagon
6th Jan 2014 9:31pm |
jimbob7
Use silicon spray because oil,grease or WD40 will just attract more dirt. Pov.spec,ftw. 2006, 110,TD5.
7th Jan 2014 1:28am |
