Home > Maintenance & Modifications > Let there be light
Leenorthants
Let there be light
New spots mounted, 18w, 1260lm led spots.
Unboxed
Brackets on
Lights on
Post #295813 4th Jan 2014 9:12pm
landy andy
They look good Thumbs Up
Can I ask what make? Cost? Quality?
Andy
Post #295827 4th Jan 2014 9:41pm
jimbob7
Beam shots are good fella Thumbs Up ,long, pitch black, straight road with reference markers in the distance. Pov.spec,ftw. 2006, 110,TD5.
Post #295837 4th Jan 2014 10:06pm
Leenorthants
Ł50 the pair, Only Chinese lamps, but full metal case and stainless fixings, more pics to follow.
Post #295850 4th Jan 2014 10:25pm
Cheshire110
Interestingly I just bought 4 of the exact same off eBay!
Hopefully should arrive Monday, are they good?
Any shots of what they light ahead up like? Cheers, David
Post #295887 5th Jan 2014 1:36am
ade666
United Kingdom 2003 Defender 110 Td5 DCPU Belize Green
Been looking at these on the bay myself to use as rear work lights on my dc. Would love to see a pic david when you have them on. 110 double cab in belize green.
Few little mods here and there
300 tdi disco
Post #296079 5th Jan 2014 7:23pm
Cheshire110
To be honest I imagined they would be a flood beam (50/60 deg) but looking at the advert more closely(as I should have done!) mine say 'spot beam'
No clue what a spot beam is? Like normal high beams?
Oh well will have to see what they're like.
If someone finds the exact same in 'work/flood' beam I'd be interested Cheers, David
Post #296082 5th Jan 2014 7:28pm
Litch
I have been using a pair of the twin LED spots from the same manufacturer on my bike (BMW GS) since the summer and they are excellent.
The same lights are available from several suppliers (I use MTFANSCLUB) and are available in several configerations including 2, 4, 6, 8 12, 18, 24 and upto 96 LED's (probably others as well). They are not E-marked but as far as quality & performance goes they are unbeatable for the money.
I am fitting an eight LED flood on the rear of the 90 as a work-light. I had held off ordering it until I had thoroughly tested the ones on the bike but they appear to be holding up just fine so fitting is imminent. My main concerns (apart from the light pattern) were failure of the LED's, water ingress and damage to the lense. In all cases my worries have been groundless so I am happy to purchase more lights. ONE LIFE, GET IT!
Post #296120 5th Jan 2014 8:59pm
Cheshire110
Thanks for the good appraisal, hopefully mine will appear tomorrow so should be able to see for myself Smile Cheers, David
Post #296168 5th Jan 2014 10:38pm
gavinpm
England 2006 Defender 90 Td5 SW Cairns Blue
Litch
Does the LED flood you're fitting have a switch ?
Thanks
Gavin
Post #296830 8th Jan 2014 11:48am
Leenorthants
Post #296950 8th Jan 2014 5:47pm
Cheshire110
Any chance of some beam shots sometime? No worries if you're busy or can't Smile Cheers, David
Post #296970 8th Jan 2014 6:40pm
Leenorthants
Tried last night bu my I phone is crap at night shots, they are more of. Flood than a pot, but def worth installing!
Post #296982 8th Jan 2014 7:23pm
Cheshire110
No worries. Glad to hear you mention flood as that was more what I wanted..
Only read the bit that said 'spot beam' after is bought! Embarassed Cheers, David
Post #296985 8th Jan 2014 7:26pm
Steve R
2013 Defender 110 Puma 2.2 USW Keswick Green
I'd also be interested in a few pics of them installed David. I'm considering trying a couple of these as rear worklamps for camping trips etc so am also more interested in a flood type beam pattern. Thumbs Up
Post #296996 8th Jan 2014 8:00pm
