![]() | Home > Puma (Tdci) > Tapping onto the alternator cable |
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
I also like this version (off course - I am Dutch ZeDedender, I did tap into the feed from the alternator, was very easy, but I have a 300 Tdi - don't know if there is much difference with the Puma alternator setup... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Apparently the Puma is a bit "awkward" (in so many ways) compared to earlier models but that's okay. Originally I rigged it (in a rather ugly way) to the battery to test it (until I got LEDs) it so I'll just find a neater solution. In any event, there's a hell of a lot going on in the battery box already, so another wire won't hurt
But shout it at them in German because life is also terrifying and confusing... |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Matt,
As with a builder's house looking like a building site my battery box as an electrician looked a bit like a bowl of spaghetti (albeit a safe one). I decided to tidy the lot up and run in new cables for future use too. I used a Blue Sea 6-way and sorted it all out in one go, worth the efoort and makes future installations so much easier. Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Perhaps verging a little on the OCD don't you think But shout it at them in German because life is also terrifying and confusing... |
Afterthought:
My only final decision re. the lights is whether to rig them to the main (starter) or auxiliary battery (via the BlueSea fuse box). One advantage might be that there will be no current drop with the second battery on starting as it's not normally connected. Also, even if the second battery runs flat, I can always connect the two while it charges. I can't help wondering if I've missed something though? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
I do admittedly suffer from mild OCD. That's why I'm so appreciated in the 'Marine Bodge It And Scarper Bigade' I still work to military aviation standards - Takes a little longer but only has to be visited once.
| tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129
Hi ZeDefender,
regarding tapping power from the alternator in a Puma defender, it is quite easy actually. just on the driver side of the engine, you can find the alternator and the power(positive) output nut is quite exposed with a rubber cap on it. if you open the rubber cap, you find yourself a nut securing the main power cable to the car battery. what I did was put addtional wire there and tap the negative on the air con fixing nut. just want to confirm that, I believe all puma defender are fitted with relay to the headlights? they are the R122 relays on the diagram? THanks Martin |
| All times are GMT |
