![]() | Home > Puma (Tdci) > Rusty door lock. |
forest172 Member Since: 01 Nov 2012 Location: derbyshire Posts: 355 ![]() ![]() |
Mine did that after a few weeks. But not the passenger one
Door lock/mechanism is very exposed to the weather on a Defender, brake/clutch/electrical cleaner for cleaning and silicon or white/lithium grease fer lubing. Pov.spec,ftw. 2006, 110,TD5.
landys1 Member Since: 04 Dec 2013 Location: Cheshire Posts: 134 ![]() ![]() ![]() |
Spray all the shiny bits you don't want to rust (locks, exposed bolt heads etc.) with ACF-50 - marvellous stuff! 1959 Series 2 Ragtop
1989 SWB Stationwagon 1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work) 2011 Puma 90 2.4 XS |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 419 ![]() ![]() ![]() |
+1 acf-50
Got some photos? |
Eric L Member Since: 16 Aug 2007 Location: IN93uc Posts: 15 ![]() ![]() ![]() |
Hi,
No issue with mine ![]() |
AlisterC Member Since: 25 Apr 2012 Location: Somerset Posts: 116 ![]() ![]() ![]() |
The lock barrel on my 2011 seized completely, and made the central locking fail, according to the dealer. The car was stuck in the dealers for 2 1/2 weeks because they couldn't get a replacement. In the end they changed all the locks, because although they couldn't get an individual barrel, they could get a complete lock kit for all doors / ignition
So yes, it does happen |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
I insert the metallic end of the key twice per year into a tube of Liqui Moly silicone grease and then put it into the drivers door and rear door locks and turn it a couple of times. Sofar, so good in its 5th winter ![]() But the lock you mention on the passenger side ![]() ![]() ![]() ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Eric, that's a really good idea, I will be doing this from now on
Thank you |
