Home > Tdi > What tools and spares do you carry when off roading?
Criffel
United Kingdom 1994 Defender 90 300 Tdi HT Rutland Red
I gave recently bought a 300 Tdi, and have gad some gentle off road experience in my Disco3. I plan to do more in the Defender. What tools and spares would you recommend I carry with me?
Advice welcomed. Thanks in advance. Thumbs Up 2011 D4 Nara Bronze
2007 Discovery Rimini Red. Gone. Thanks for the memories.
1994 Defender 90 300 TDI - Galv chassis
No one warned me Land Rover are not cars but an obsession!
Post #295184 2nd Jan 2014 7:10pm
K9F
http://www.defender2.net/forum/topic25529.html?highlight=toolkit
Whistle Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #295203 2nd Jan 2014 7:46pm
Criffel
Cheers K9F. Did do a search first before posting but didnt come up with anything that answered my question. 2011 D4 Nara Bronze
Post #295206 2nd Jan 2014 8:07pm
GUM97
That thread doesn't cover off roading though, just general tools Wink An engine to TDi for!
Post #295267 2nd Jan 2014 10:12pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
First get it protected: steering and diff guards, maybe HD steering and tracking rods or wait untilyou bent one (like I did).
2 shackles
1 kinetic rope
A good jack, hi lift when mud is expected
A small waffle board as jack base
Should actually add another shackle and load divider soload is divided over the 2 front recovery eyes.
And at least one full size waffke board.
But what I have now is the very basic.
But most importantly: make sure you have proper recovery eyes back and front and tonot go alone so you can recover each other.
Later you can maybe consider a winch but it's not a beginners tool. Still don't have one yet and it's still not a priority for me.
Will furter protect the underside and get a spare wheel carrier before a winch.
Post #295290 2nd Jan 2014 10:52pm
landy andy
For off road, I would carry the tools and parts to change
wheel bearings, (hub nut socket, socket set, grease gun, silicone sealant)
Prop uj's (imperial spanners, sockets, hammer, grease gun)
Alt drive belt (fan removal spanners if required)
Bulbs (screw drivers)
Spare wheel (jack, wheel brace, wheel chock)
I also carry wire and a few connectors, fuses, 14mm ratchet spanner for removing challis, threaded bar and nuts. And loads of other stuff Big Cry
Andy
Post #295298 2nd Jan 2014 11:09pm
The one essential tool without which I would never venture off tarmac is a good shovel.
Post #295302 2nd Jan 2014 11:32pm
Weston18
England 1999 Defender 110 300 Tdi DCPU Tonga Green
Maybe worth carrying spare shafts and cv's dependant on what type of off roading you intend to do, laning or play days or challenging/comps.
Personally for laning I carry a 150pc socket set, pliers, cutters, small handsaw, knife, small compressor, screwdrivers and a jack.
Recovery wise, 2 strops and a few shackles.
Cheers.
Post #295308 2nd Jan 2014 11:52pm
Criffel
Thanks for the advice everyone. Bow down
Must start that shopping list Thumbs Up 2011 D4 Nara Bronze
Post #295334 3rd Jan 2014 1:43am
JWL
To be honest f you keep up with maintenance on your motor, you lessen the risk of anything going wrong when ou and about. I have all manner of tools and spares in my motor, that is mainly as I do a fair amount of spannering and most of the stuff stays on board as I know where it is. I do a fair amount of greenlaning and I can say hand on heart that I have allways driven home, as is the case of pay and play sites I've been to.
The one thing I would say is carry a few commonly used spanners, 10mm, 13mm, 14mm, 17mm and 19mm. A quality adjustable, mole grips and a hammer. Some sockets to match the spanners, few spare fuses and a small selection of bulbs.
The only things that have happened when out and about with others have been the odd puncture, a UJ failure and a drive flange stripped out. The latter two were sorted by taking the prop off and in the case of both of them driven home on diff lock.
The main thing is preventative maintenance.
Post #295336 3rd Jan 2014 2:48am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
think you need a 110 to carry all these suggestions! Whistle Whistle 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #295347 3rd Jan 2014 7:53am
Criffel
Thinking about it you have most of this already DT,......... except the spare hub. 2011 D4 Nara Bronze
Post #295350 3rd Jan 2014 8:15am
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
make sure you go with someone in a toyota so they can tow you home Whistle
i'll get my coat Embarassed Have fun be happy
Post #295669 4th Jan 2014 12:36pm
Criffel
Rolling with laughter Rolling with laughter
So a 110 to put the tools in and a trailer for the Toyota.
Cheers guys Thumbs Up 2011 D4 Nara Bronze
Post #295672 4th Jan 2014 1:01pm
