![]() | Home > In Car Electronics > Neg terminal |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986
Also am I correct in thinking that if I back power the live system, (via purple wire in the rear area), that it's only the small red wire one the live battery terminal will remain live once they are separated from each other and the battery?
Andy. |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
I just made a new one
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205
That would make sense, as I'd imagine the big red cable would go to the starter and/or alternator. Although you'd have to check to be sure. Are you thinking of back feeding it so you don't lose stereo memory or alarm function? |
Thanks Ken, when you say made new one, do you mean cable, and joined it, or connection/terminal on original cable?
Yes Jamie don't won't to cause alarm problems, loose stereo settings, may want to keep it locked and alarmed overnight with out battery in place as want to seal all the holes in the battery box, might even Dynamat in there. Andy |
