Home > Puma (Tdci) > Injectors damage the engine??
Harryb450
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
in the link below it says its the injectors that damage the tdci engine is this a load of rot?
http://www.ebay.co.uk/itm/Land-Rover-Defen...19e5dcbd18 NO ROAD..........EXCEPT FOR LANDROVER
Post #294346 30th Dec 2013 9:59pm
K9F
Twice in as many days I get to use the following image....
With the phenominal mileage people like noworries4x4 have covered in their vehicles this would have been an issue we would have known about.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #294433 31st Dec 2013 12:07am
EGR is more likely to be the issue. Rolling Eyes ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #294434 31st Dec 2013 12:09am
Harryb450
Thumbs Up Thumbs Up I thought it to be a load of rot, but thought I'd check Thumbs Up NO ROAD..........EXCEPT FOR LANDROVER
Post #294580 31st Dec 2013 4:07pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
How can it be a road legal Tdci ? I thought the Puma 90 only came, legally, as a 4 seater? LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #294632 31st Dec 2013 6:16pm
I think that's academic as the pictures show no seats in the rear at all Rolling Eyes Basically, the advert is rubbish. Darren
Post #294640 31st Dec 2013 6:38pm
Mines got 6 seats, but not used anyway. Rolling Eyes A lot of ads have errors like these on, I've seen Puma listings with engine listed as 4L sometimes and things like that yet it's obvious it's the standard motor. ____\We|Will|Win/___
Post #294642 31st Dec 2013 6:40pm
noworries4x4
As above Censored !! Both my Puma engine failures have been through oil pump / oil pressure issues, the 2.4 went bang on the A303 early one morning when the pressure relief valve stuck / failed pumped the head turbo ect full of oil result big bang and lots and lots of smoke fire ect.
The second 2.2 Puma as every one knows died in France this year oil light just came on at 100km/h oil pump drive sheared simple as that, then the recovery people kept driving it to move it from truck to truck in the yard ect and was knackered when stripped out.
I have had turbos numerous egr valves ect on the 2.4 heat shields and manifolds on both but never injectors or high pressure pumps except for an oil seal leak. The only fuel related item I have had under warranty was a high pressure gallery the metal cracked one end fuel everywhere. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #294861 1st Jan 2014 2:25pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Advertised as Decat as well so on legal rough ground with that. www.td5.org
Post #294903 1st Jan 2014 5:01pm
K9F
FFS...Not the old Decat debate again please! Whistle
There is NO rough ground at all. Ignition sparked engines only NOT diesels post 2012. Thumbs Up
http://www.defender2.net/forum/topic10363.html?highlight=sparked
K9F wrote:
dorsetsmith wrote:
Confused It would seem not clear DE-CAt will resolt in MOT failer from 2012 matthew
Rubbish! It is crystal clear! If your Landy runs on petrol you're stuffed! Diesel not being 'petrol ignition sparked' you're ok! Thumbs Up
I feel that the issue of cats is going to run and run despite it being quite clear! Whistle
It has been covered at least twice before in some detail. Look at the link below and follow the link in my first post on this thread to the original thread....
Thumbs Up
http://www.defender2.net/forum/topic9379.html?highlight=decat
Post #294923 1st Jan 2014 5:52pm
vito115
Dont think its unheard of for the injectors to kill the tdci in the Transit, mostly 2.2s with Densos i think ?
Post #294967 1st Jan 2014 8:53pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I'm fairly confident it was the dodgy injector that killed my 2.2.
Post #294995 1st Jan 2014 10:14pm
Eric L
France 2007 Defender 110 Puma 2.4 SW Alpine White
You can :
http://www.defender2.net/forum/topic6656-45.html December 2007 110 Defender. 106000 KM
Post #295866 4th Jan 2014 11:05pm
munch90
Delphi injectors in transit were proper ****. and heard of cracked pistons because of dodgy injectors .
but Bosch injectors are much better ok we had a few Bosch ones play up but can't think of any causing damage.
. think it was on that post I asked if he had any running problems before the knocking started and he had .
so really if running problem sorted first may not had any other damage just replace injectors
Post #295874 4th Jan 2014 11:23pm
munch90
we had a rep in from Delphi and he was saying the new injectors were going to give trouble because the old euro 4 injectors had something like 8 holes to give spray pattern and new euro 5 needed something like 20 holes to give extra fine spray pattern for euro 5 emissions
so if the holes are that much smaller they are going to block easier and give bad patterns
Post #295879 4th Jan 2014 11:54pm
