![]() | Home > Puma (Tdci) > Any experts in the essex area that know a puma inside out? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Have you tried reversing a few metres to release difflock
![]() Last edited by ibexman on 1st Jan 2014 3:22pm. Edited 1 time in total |
Ian Mac Member Since: 16 Oct 2013 Location: Essex Posts: 53 ![]() ![]() |
last time about a hour of playing around mate, but its just one of the symptoms I've had
Ian 2008 TDCI 110 XS 1985 90 300tdi. Gone 2005 RR vogue TD6. Gone |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6197 ![]() ![]() ![]() |
Sometimes you need to wheelspin it in reverse (or I prefer to just pull up onto a grass verge and spin it a bit, sometimes just "rubbing" the verge when travelling is enough) to get it out... my 110 with a god-knows-how-many-miles t/box is like this.
sometimes turning steering while reversing helps |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
Ok minty from the landrover experience south west told me this and it works Everytime in seconds
![]() ![]() Stop - take it out off diff lock and into normal - put handbreak on - put it into reverse - let clutch up till it bites slowly and it try's to move back - and hay presto out of diff lock Best thing ever ![]() ![]() DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
It may also be worthwhile checking the diff lock switch and wiring loom. It may that the diff is disengaging as normal but the switch is faulty. Easy option is to do a open / closed circuit check with a DMM. At least you will be able to discount the switch as the issue
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5969 ![]() ![]() |
Where abouts are you in Essex?
Andy |
Thanks all
I don't believe the issue is the diff lock….. I have had a lot of slack in the drive train and a lot of bits have been changed. I'm not sure wether its just me thinking the slack is worse than normal, or it may just be normal and I'm expecting too much from a defender…. I have got a slight whine and some clunking but not sure if it is normal or a issue, causing all of these symptoms Im located in Basildon Thanks Ian 2008 TDCI 110 XS 1985 90 300tdi. Gone 2005 RR vogue TD6. Gone |
Shirty Carpet Member Since: 10 Nov 2013 Location: Essex Posts: 31 ![]() ![]() ![]() |
Have you tried one of the local Land Rover specialists?
Dan Smith at DS Automotive (just off Progress Rd, Eastwood) or Essex 4x4 in Wickford? I've not used either for anything on my Puma as I've not had it long, but have used both for my Disco and have been impressed with both. |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
I had a lot of slack in the drive train from new. Trouble is I took it to the local stealership, who didn't do a lot. I asked for a new rear diff at 5ooo miles but they wouldn't have any of it. Diffs shouldn't burn you when you touch them was my question. They did change it at 10,000 miles after a lot of pushing.
After a new front diff, it drives like new, or in my case better than new. Oh and a new UJ as well. So my advice is to keep clear of stealerships unless you need a warrantee claim. Merlin |
