![]() | Home > Off Topic > Are there RHD Unimogs? |
| Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670
Ive seen one or 2 agri spec ones with the wheel on the right but must admit they are normally on the left.
| RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596
I've seen a 2010 model with rhd
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219
A few here: http://www.unimogs.co.uk/unimogsforsale.asp
Although a lot seem to be LHD. |
| Luismi Member Since: 04 Nov 2010 Location: Cotswolds Posts: 178
in the new ones you can put it both sides.
http://yoshimichi.blogspot.co.uk/2013/04/blog-post_8432.html |
| JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532
You can get the U400 in rhd and many of the electricity companies use them for overhead work.
I've trained on 3 of these in the last 6 months, great vehicles with incredible off road ability. Our vehicles were interesting as they stood 4 or 5 metres high with a 40 foot insulated boom on the back making the centre of gravity very high!! They also don't have a low box but an 8-speed pre select gearbox instead so you usually pull away in 3rd out on the open road. I've been a great fan of these since Mercedes introduced the MB Trac in the the 70's. |
| me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856
Where did you train on those JR? www.td5.org
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
I,ve just been reading an article (with lots of pics) on MSN hone page on extreme winter cars and it says the unimog can be changed from RHD to LHD in under a minute.
By the way the Defender is picture 35 if you,re going to have a look at the article. 2005 Td5 90 XS Steve |
| 22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153
All the ones Southern Electric had were RHD when I was working there. 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
| SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1733
The Rescue one at work is a 2010 one in right hand drive, so yes you can get them and wouldn't have thought it would have been converted for them? There amazing bits of kit Id love to have a go in it off road, but they've only given us a ride in the pinzgauer so far
Cheers Tom Defender puma dormobile camper |
| Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756
Funnily enough all the ones used in Germany for highways maintenance seemed to be RHD as it meant the driver was sat kerbside and was better placed to see the jobs he was doing such as cleaning reflector posts or drains or whatever. For the same reason it is possible that many brought to the UK for specced as LHD hence people assume that was the only option?
me@td5.org: I was training Scottish Power staff in Dumfries & Galloway and Stirling. I also took some more courses at Cumbernauld a number of year's ago. These courses don't come around all that often but I really enjoy them when they do. I train under the BORDA banner up here in Central Scotland.
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
Yep, they sure are in RHD! And I have the pleasure of having one at my disposal
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045
Gum97. do you offer rides in said Mog's? 1999 Defender TD5 110
| camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3418
The majority of the square cab mogs are LHD apart from the odd few.
The newer round cabs can typically swap between Left and Right within a few minutes. Lovely piece of kit, here's my last one making the defender feel a bit insecure Click image to enlarge ![]() |
| All times are GMT |
