![]() | Home > In Car Electronics > Battery question |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
Get as big a one as you can fit in the box. Numax are very good.
Alternately, go to Costco and get a Bosch S5 for £50 or so, with 5 year guarantee. There'll be a leaflet telling which you should have. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20975 ![]() ![]() |
You want a genuine battery if possible.
![]() Genuine batteries last for a long time. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 ![]() ![]() ![]() |
Delphi Freedom, 12V 110Ah, CCA 800A, Delphi part number 19001340, LR part number YGD100860
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6029 ![]() ![]() ![]() |
Cheers. 800cca is a bit higher than what I have now! 1999 Defender TD5 110
This genuine battery Delphi Freedom, 12V 110Ah, CCA 800A fitted in too my TD5 90 back in 2003 By LR
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 285 ![]() ![]() ![]() |
I have always found that a quick and simple method of comparing battery quality is the weight, the heavier the battery the more lead it has in it when comparing say a 110AH to another 110AH. There is little substitute for more lead, the more the better it will perform and the longer it will last. 2008 Defender 110 XS CSW
Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
+1 for Bosch at Costco. I have used these for years, brilliant batteries for the money, plus the warranty. I think its 110AH, 800CCA but can check later if you need the exact spec. cheers simon |
Is the Bosch battery deal a limited thing at Costco? 1999 Defender TD5 110
I don't think so, I just buy as/when I needed them. Depending on the store, they may be in the tyre dept.
Cheers Simon |
Cheers.
So what causes the corrosion on the battery terminals? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Dampness usually causing an elecrolytic battery type effect between battery post terminal and terminal connection. Coat with a liberal dob of vaseline.
![]() Treat every day as if it is your last....one day you will be right!! |
Silicone grease (do have couple of tubes) a workable alternative to vaseline (which don't have)?
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
That'll do nicely. It'll stop any moisture and/or air getting to it.
battery terminal spray is very good .. I use it on the battery , any electrical connection I touch on defender gets a spray .. outside sockets , towing sockets (spray it on wire connections to socket and in plug ) ,all light connections, relays sockets etc
never seen any corrosion on electric joint after using it |
