Home > Maintenance & Modifications > Mounting a head unit for HF / VHF / UHF - Puma
Cold_n_Wet
Norway
Right, before I rip the dash apart, I'll ask a couple of questions before the angle grinder and drill come out.
I want to mount head units from a Kenwood D-710 and a Yaesu 857 TD radio's on the dashboard of a puma.
Ideally in the centre consul above the clock, now before I start to dismantle it ( Ive have it a week now) I think its best to ask what have others done ???
a quick picture of the tempaoery mount in the D4.
 "Rafiki" 2007 110 STW - Rolling rebuild.
Post #294460 31st Dec 2013 1:42am
Puma pod required
Post #294462 31st Dec 2013 2:03am
Cheshire110
Puma pod waaaay to small unfortunately.
On the mud uk website they sell a roof console option (http://www.mudstuff.co.uk/products/interior-trim/mud-defender-roof-console.html) and a simple tray for the passenger side which is neat and tidy (http://www.mudstuff.co.uk/products/interior-trim/mud-defender-puma-single-din-dashboard-mount.html)
You can also mount on inside the cubby box (on the inside of the front face, facing upwards) which is discrete and handy considering most don't use CBs that regularly. Negative: involves drilling holes in base of cubby for wiring.
What I did was purchase a handheld CB with car kit and aerial mount included, and fit it alongside my cubby so I can tuck the unit inside the cubby when not used, and pull it out when necessary. See my pics half way down the page here: http://www.defender2.net/forum/topic24368-30.html Cheers, David
Post #294493 31st Dec 2013 10:13am
Puma Pod is not to small if the UHF has a demountable face unit pic suggests this is the case
Roof console is to small unless single din is shallow or your willing to cut the Head linning
Theres also a plate by Mud that fits a single Din under the glove box in the Puma
Or for complete set up a Double Din cubby from FCX
Post #294498 31st Dec 2013 10:24am
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
FCX sell a 'twin din' cubby box, might be able to do something with that?
Might mean a bit less butchery to the dash.
Post #294502 31st Dec 2013 10:39am
Cold_n_Wet
Norway
I really need to mount the Kenwood on top due to the GPS pod needs contact with satellites.
The Yaesu could be hidden away, but I need access to them as well.
I have thought about the roof console from Terrafirma.
What is under the plastic behind the clock, could a couple of selv taping screws go in there ?
Glen "Rafiki" 2007 110 STW - Rolling rebuild.
Post #294527 31st Dec 2013 12:01pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Could you use this?
http://www.mudstuff.co.uk/products/interio...nsole.html
maybe relocate the roof light for extra space to fix stuff? Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #295413 3rd Jan 2014 1:22pm
