![]() | Home > In Car Electronics > Fitting Amp/Sub RCA & Power on cables |
Depends what head unit you have and what route you're taking with the cables, if you can gain access via the passenger footwell quick-release access panel (same sort as your fusebox one) to route and connect the cable in. In this case you would only need to take the radio out and not the centre dash. If you go through life with your head in the sand....all people will see is an ar5e!!
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1451 ![]() ![]() ![]() |
http://www.defender2.net/forum/topic16968....sh+removal
Thought this might be of some use to you ![]() |
Bionicmunky Member Since: 15 Oct 2013 Location: High Wycombe - Buckinghamshire Posts: 108 ![]() ![]() ![]() |
It's the alpine one (my2013 Puma XS).
Any idea which removal keys I need from Halfrauds? Cheers again John |
another helpfull link ?
http://www.defender2.net/forum/topic20983....+unit+keys ![]() |
Thanks Jim
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
No real need to remove the centre dash at all really, you should get all the access you need through the radio aperture and from underneath as K9F describes.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
