![]() | Home > Maintenance & Modifications > DRL bumper fitted (thanks Killer90) |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
Glad your happy
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2789 ![]() ![]() |
Yes, certainly if you wish! Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
There is a 2 way relay, has 5 contacts that will switch from one circuit to another. You have main power in going to DRL. So DRL's are on when power is applied. When side lights are switched on then relay switches power to circuit 2 which is connected to NOTHING. So DRL come ON with ignition and go OFF with sidelights. Simple. I presume if you just wanted them to dim with sidelights then a suitable resistance in Circuit 2 and connect to DRL would do the job. Ignition ON - Circuit 1 active - Full power to DRL. Sidelighta active - Circuit 2 active with resistance - 1/2 power to DRL.
I just have them switch off with sidelights on.Passed it's MOT with no problem. Tester was interested as to how it was set up. ![]() ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
You may be able to help me?
I've fitted my DRLs as you can see and would just like to be able to dim them when a circuit comes on (sidelights in this case) Does an LED dimming relay exist? I don't want the voltage sensing bit though... Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Ah, ok good!
I'll buy one when I get back from uni Thanks Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Captain Speaking Member Since: 23 Jan 2012 Location: Oxfordshire Posts: 159 ![]() ![]() |
![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
(Re-)read Go Beyonds' reply - this the correct way to wire them in with auto on/off AND your requirement to turn them off manually.
![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
