![]() | Home > Puma (Tdci) > LR approved Eberspacher or equivalent? |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
May I suggest you have a few words with Derrick at LRS. Site sponsor and He seems to know his way around the Webasto set up as he supplies and fits them.
Site sponsor and his web address is www.lrsshop.co.uk Brendan |
| Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 251
For heating the coolant, Webasto Thermotop C have been fitted for the scandinavian markets since 99, and still are fitted today.
For hot air the Airtop 2000 is a favorite mounted under 2nd row seat. The AT is a little easier to install as you dont need to wire in cabin fans or water pipes. Both can be installed with timer and remotes. Glen Edit:- these are not factory fit, these are mounted in Norway at the docks when the vehicles are delivered. "Rafiki" 2007 110 STW - Rolling rebuild. |
| tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134
Hi, try Robert, at Info@Eberspacherparts.com, very knowledgable when it comes to heaters
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
Quite a few members have fitted webastos or eberspachers, both "block" and "air" heaters.
I bought a thermotop C kit from Derrick at LRS as a complete kit, but they do come up on ebay - you get what you pay for Depending why you need one will help determine whether you have an air heater or a block heater. A block heater will also heat the cabin using the regular vehicle heater once the block is upto temperature. Depending on whether you go wading/off roading, will help determine the positioning of the block heater. Also whether you have LHD or RHD vehicle. Air heaters tend to be mounted under the 2nd row seats, or in some models (td5's) can be fitted inside the seat box where the fuses are housed with some modifications. good luck ! |
| AWOL Member Since: 31 Oct 2013 Location: UK Posts: 222 |
Thanks guys.
Sounds like a call to LRS is in order. |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480
some Military LRs - HS TUM WW versions have webasto engine coolant heaters and extra associated plumbing for radiators around the battery box and in the rear. Cheers
A cheaper alternative is a kenlowe block heater, these are simple to fit but require 240v mains. OK if you want to heat the block at home, or with a portable generator
http://www.kenlowe.co.uk/pre-heaters/cars/howto.html |
