![]() | Home > Maintenance & Modifications > Drop plate options |
Simon27 Member Since: 30 Oct 2012 Location: East Lothian Posts: 131 ![]() ![]() ![]() |
I've recently purchased a Dixon bate 5 tonne jaw and tow ball but it uses the 4 bolt fixing instead of 2, which I understand matches the size and spacing of a NATO hitch.
Are there any options beside a Dixon Bate sliding drop plate to fix this with? When looking at the available sliders, it was hard to find ones that definitely have the right spacing. |
Thanks, so I could in theory use the current plate that's there, but I just wonder how packing behind with washers helps when the holes are still larger?
It's really more of to use it as a strong rope towing point than for serious on road use. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17943 ![]() ![]() ![]() |
Although if you need to tow a trailer which has a 2" ring coupling you will need a 5-ton jaw. |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 536 ![]() |
You use washers larger than the holes to spread the load and prevent the smaller bolts pulling through the large holes. If you search you can buy thick washers suitable for this purpose or even buy a military backing plate made from 1/4" steel with the correct sized and spaced holes specifically for the NATO hitch to spread the load on the LR crossmember which could also be used on the std drop plate
Why? The standard DB ball & jaw will do this |
Thanks for the replies everyone. The old tow balls been marinating in WD40 overnight so I should be able to get it off today.
The backing plate sounds like a possible option, so I'll have a look for that. |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
WD40 isn't a penetrating fluid, so you may have better luck in the future using something like plusgas,
