Home > Td5 > Light Steering? |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 856 |
Depends on tyres and road conditions, also suspension set up.
28th Dec 2013 9:01pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Hi LLamakarma,There,s a thread on here somewhere regarding "door bounce back" i followed the instuctions in it and my passenger door has never done it since.
Basically the grease in the door latch hardens and stops it working correctly when cold spray the mechanism with WD40 liberally and it flushes out the old grease and normal service is resumed. Try a seach for the thread,Hope this helps. 2005 Td5 90 XS Steve |
28th Dec 2013 9:14pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
at 22psi I would think the tyre is rolling over onto the side wall. If you are running standard 235 85 16 tyres I would suggest you set the pressures to Handbook recommendations or at least 28F 35R and see how it feels.
What tyres are you on, tread depth and age of the tyres? Also are your springs and shock absorbers [dampers] in good condition? BM52 |
28th Dec 2013 9:50pm |
Llamakarma Member Since: 28 Dec 2013 Location: North Bucks Posts: 3 |
Thanks guys for the advice.
I've adjusted the tyre pressures today - handling is about the same so think it is probably just me! Interestingly, my original pressure gauge registers about 4 Psi more than the two I've just been given, hence the pressures were running lower than I thought. Tyres are General Grabber, probably about a third to half worn. I'm not aware that the shockers are particularly worn. Defender is a 52 plate, 79k miles and it appears to have been well looked after. I'll look out the thread about the bouncing passenger door! Thanks again. |
29th Dec 2013 6:00pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
Couple of things come to mind.
Does your vehicle have front and rear anti roll bars ? I have just changed all the front and rear radius arm bushes on my 51 plate TD5 for Superpro bushes and they have certainly removed any light feeling when cornering (I do have ARB's on mine). Maybe your bushes are on their way out, if they are the originals they are probably a bit tried after 11 years. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
29th Dec 2013 7:20pm |
