![]() | Home > For Sale & Wanted > [Wanted] Front and Rear ARB (Anti Roll Bars ) Now Sorted |
Might be worth changing your title to anti roll bars as I presumed you were looking for ARB lockers ...
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1457 ![]() ![]() ![]() |
Done Matt !!!! Forget landrover speak
hi Jim
I saw a new front and rear pair on ebay this morning |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
Jim,
I'm contemplating taking the anti roll bars off my 90 HT - if you don't get fixed up, let me know. Cheers Simon |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6048 ![]() ![]() |
Got a set in the garage, will dig them out and let you know. They were off my 90 hard top
Andy |
Steve, thanks already watching a couple on the bay, but would prefer to spend with a fellow forum member
![]() ![]() Simon will do thanks ![]() Andy could be great, youre not too far away ![]() |
Got these original ones. Only one bar has the clamps and on one bar the drop link rubber boots are perished. But yours for £25.
So I should be able to make 1 good bar fit, and then want 2 new links and 2 straps/clamps, (which seem harder to source)
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 ![]() ![]() |
The ARBs off a disco fit and work just fine. Might be easier to find. Not sure on a 90, but the only difference on a 110 is the rear chassis mounting bracket has 4 holes on the defender and only 2 on the disco. Otherwise a straight swap.
Mountain Man- Many Thanks but, I am led to believe that they changed slightly Tdi to TD5, gaining a kink to clear the diesel tank ? To get arond this you may need to fit spacers. I am no expert, but a knowledgable forum member informed me of this subtle difference, whilst I was bending his ear
Mine was from a 04 reg Td5 hardtop. As you mentioned it has the step in the rear one for the fuel tank. This rear one is the one I can't find the clamps for, but I might be be able to find them with a bit more searching. The front one is complete but I changed the drop links to Brit part items, as I thought the original was causing a knock, and the boots on these are splitting
Will do some more searching tomorrow for you. Andy |
The ones I took off my TDi Disco looked the same as the ones in that photo, complete with fuel tank kink on the rear. I have, however, fitted 2 Inch spacers to allow for increased articulation due to longer shocks.
Off to see Andy tomorrow so should be sorted
