Home > Puma (Tdci) > Which Stainless Headlamp Bezel
MartinK
Quick bit of advice please fellow forumers...
Wifey bought me a set of Wipac Crystal headlights for Christmas Thumbs Up
Was looking at the various suppliers of Stainless headlamp bezels (equivalent to part # PRC7992 I believe Question ).
Pricing seems similar between Mobilecentre, bolt-on-bits, sense-of-adventure etc. Only the bolt-on-bits ones seem to come with new clips/fittings (I probably don't need them at the moment, I don't believe mine have rusted...).
My instinct therefore is to go for the Mobilecentre ones (site sponsor).
Before I buy, and pointers/experiences to share Thumbs Up
Thanks Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #293551 28th Dec 2013 8:19am
ericvv
Martin, I have those from Mobilecentre, first installed with my SVX Wipacs, now with the Speaker LEDs. No fitting problems at all with those. A friend of mine has the Nakatanenga version SS rings on his new Defender with the Nolden headlights, same thing here, plug 'n play. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #293553 28th Dec 2013 8:43am
I suspect that these things are all much the same and seem to have been around for some years in Classic Mini circles. I've got the ones from BoB and they work fine. Darren
Post #293556 28th Dec 2013 9:01am
just to add, if you are fitting around a set of wipacs, there will be no corrosion issues, so pretty much any make will work. for good measure pop a bit of dinitrol on the fittings.
Post #293560 28th Dec 2013 9:11am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Tims/Sense of Adventure will come with the clips... Putting Dreams on Drives at JLR Solihull..
Post #293580 28th Dec 2013 10:26am
MartinK
Great, thank you Gents, I'll get some ordered.
HNY to you when it comes Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #293597 28th Dec 2013 11:42am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
i bought this from minispares.. fitted my std wipacs ok..
http://www.minispares.com/product/Classic/...CBack%20to
Post #293609 28th Dec 2013 12:26pm
MartinK
Cheers, Mr James Thumbs Up
Price is about the same, so I'll order via a forum sponsor methinks. Thanks fo rthe pointer tho.... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #293761 28th Dec 2013 9:30pm
