Home > Puma (Tdci) > Clutch and Radiator
CapeLandy
South Africa
Clutch and Radiator
Took the 110 in today for a test drive with the Technical Guy at LR - says the upgraded clutch or pressure plate is toast again. Has ordered a new one for Monday but once he strips it he reckons he will have to fight with head office to get it under warranty as he reckons the updated clutch does not fail
Also found another leak on the radiator which they had repaired last time - I asked them now to put in a new one.
The service adviser told me jokingly I should flog this bad luck version and get a new one - "with what money - you guys should be offering me one as penance for all the heartache I've had with this one."
Post #29274 8th Apr 2010 12:02pm
MK
Hi
what symptoms you noticed on the clutch? Puma 110" SW
Post #29277 8th Apr 2010 12:40pm
CapeLandy
South Africa
when shutting the engine down - clunk - clunk clunk
Then driving secong gear low range at 1000 r/min up any slight incline - rrrrrrrrt- rrrrrrrt- rrrrrrrrrrrt
Best way to describe the noises it makes Embarassed
Post #29289 8th Apr 2010 6:06pm
