Home > Maintenance & Modifications > Heated mirrors
Page 2 of 2 <12
boode
England 2003 Defender 90 Td5 HT Rutland Red
Can you see the cables ? - Yes from the base of the hinge only
Wire going to dash from door - the hole is under the door seal rubber
Post #266074 12th Sep 2013 7:36pm
Greener78
2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Is there any risk the wire short circuits over time? Or is there some protection to the plastic coating on the wire?
Post #292827 23rd Dec 2013 9:47pm
Romadog
Post #292832 23rd Dec 2013 10:05pm
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
I have so far fed my wire as mentioned through the arms and round the door under the seal into into the centre of the dash, I just have not had time to dismantle the bloomin dash to get into the console and conect them up!
Does anyone know where I would graqb a feed from the front screen relay in the TD5 dash so I can use the mirrors in conjunction with that?
 He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #292848 23rd Dec 2013 10:52pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Or these without the indicator function.
https://shop.landreiziger.nl/verwarmde-spiegels-lr-defender.html Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #292861 23rd Dec 2013 11:26pm
dgardel
Italy
opsss wrong post..... Embarassed Embarassed Embarassed Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #294315 30th Dec 2013 8:30pm
Romadog
Megatoad, why don't you connect to the wires that go to the heated windscreen ??
Post #294326 30th Dec 2013 8:56pm
megatoad
Thats a thought!
As I still have not had time to do it yet.
Do you mean piggyback off each teminal on the left and right side of the screen?
Will it have any impact on the current through the screen itself? He who dies with the most toys wins Smile
LRSOC & CVLRC
Post #294523 31st Dec 2013 11:50am
JWL
It's just another thought to add to the thread but I wired my mirrors through an independant switch as I'll often have mine on when the screen is off, generally when going home at night I find that if it's damp and drizzly I don't want to have to turn on the front screen to clrar the mirrors so I can reverse to my parking spot plus the times when the screen is warm when driving but temp changes cause the mirrors to fog over.
Post #294532 31st Dec 2013 12:22pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
You also want them on permanently when it's raining
Post #294570 31st Dec 2013 3:31pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
boode wrote:
An alternative to drilling into the door is to run the cable from under the door hinge through the door pillar and straight into the dash.
The cable goes through the ball in the mirror, under the grove in the mirror arm, into the swivel joint, out of the plastic cap at its base and into the base of the hinge - then through into the bulkhead next to the dash.
Sounds complicated but is straight forward.
Jake at Devon 4x4 had an excellent thread on their forum showing how he had done his.
I copied his ideas and it looks very neat and is easy to do.
The post was called "Overland 110 Build" in the vehicle projects thread - the post is still there but with no pictures.
I am sure Jake would forward or re instate the pictures if asked. The post number is 82219.
BTW, I have the pictures from Jake, assuming he doesn't mind me posting, I can upload them or send them via PM.
Simon
Post #294581 31st Dec 2013 4:07pm
megatoad
Good point, that said, mine is a TD5 so lets face it, the bloomin windows steam up long before the mirrors !!
I think I will try for an independant feed and use the swithc provided in the kit. He who dies with the most toys wins Smile
LRSOC & CVLRC
Post #294705 31st Dec 2013 9:08pm
Page 2 of 2 <12
