![]() | Home > Puma (Tdci) > second/service |
any one got a copy of service guide.
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Do you mean the maintenance check sheet? You can get that here: Check Sheet 110 2.4TDCi
110 300Tdi ![]() LROCV ::: AULRO.com |
Nice one
No sorry and I need one now that you bring it up
![]() Anyone else able to post this information as mine is due its first service and I'm doing it in conjunction with the local mechanic - nearest LR dealer is 1100km away and roads are now closed for the wet season. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
Jaeger Member Since: 01 Mar 2010 Location: Beitostolen Posts: 32 ![]() ![]() ![]() |
I also need the first service schedule. Anyone?
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
isnīt it the same? Puma 110" SW
There should be an extra "check sheet" for the first service. Something about checking/tightening bolts and nuts and whatnot.
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
I can send scans of the above. If you send your e-mail address in a PM I will send on the scans. 1982 88" 2.25 diesel
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
one from me in miles if it helps:
http://www.defender2.co.uk/gallery/albums/...0miles.pdf Mike |
