Home > Technical > Oil Service Warning
Page 2 of 3 <123>
K9F
2.2s onward not on the 2.4s. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #292310 21st Dec 2013 8:46pm
One less thing to worry about then. Laughing _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #292314 21st Dec 2013 8:49pm
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
Cheers guys and gals for your replies,of to Roger Youngs on Monday then for a reset.
Rolling Eyes You only have one life, live it....forget the cost.
90XS Hardtop
Post #292351 21st Dec 2013 11:38pm
another tick for 2.4s
Post #292374 22nd Dec 2013 10:15am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Does the service light have to be reset by the dealer ? Lots of cars have a sequence for resetting service indicators i.e Ford cars is something like depress both brake and clutch pedals turn on ignition keep both pedals depressed for 20 seconds with ign on the turn ign off release both pedals and turn ign on and voila service light is reset ! and the dealer will charge you forty quid for that !!!
Might be worth a web search or you tube search before going to the dealer. 2005 Td5 90 XS
Steve
Post #292377 22nd Dec 2013 10:28am
K9F
Search revealed.....
Here's a link for the 2.2 TDCI Ford Transit resetting....
And another method of resetting the service interval for 'Late Land Rovers'...
http://robisonservice.blogspot.ie/2010/01/...-late.html
Someone give them a go and report back please.....Doubt it'll work personally but well worth a shot perhaps. Question If you go through life with your head in the sand....all people will see is an ar5e!!
Post #292379 22nd Dec 2013 10:42am
Lou Sparts
I was only one pedal out ! 2005 Td5 90 XS
Steve
Post #292381 22nd Dec 2013 10:55am
GUM97
The second one works for the Feeelander 2's, and IIRC Discovery 3's. Not sure about the Defender though! An engine to TDi for!
Post #292390 22nd Dec 2013 12:03pm
Sonarmender
This morning the OIL SERVICE LIGHT was not on when I started the engine but I had booked into Roger Youngs for them to reset it anyway so off I went.
On arrival I explained the stop start running and low mileage from the last oil change and the fact that this morning it was no longer showing the OIL SERVICE WARNING.
The service manager asked if i had done any longish runs prior to the OIL SERVICE WARNING light no illuminating.
Funny old thing (I did a quick blast to Exeter last night probably about 25 miles of dual carriageway).
Anyway the service manager told me that the OIL SERVICE WARNING LIGHT will illuminate prior to the ecu requesting a DPF Regen.. if the regen is not completed i.e. stop start running it will stay illuminated until it has completed the regen.
They did a fault read and it had registered the OIL SERVICE WARNING, so they duly reset it for me, washed the vehicle and it cost me sweet FA.
Top service from Roger Youngs yet again. You only have one life, live it....forget the cost.
90XS Hardtop
Post #292994 24th Dec 2013 6:34pm
OK.
Tried them both.
The transit method is clearly far more simple. Not sure what that says about the imtended drivers of said vehicle or maybe the engineers behind it! In any event it did not work on my Defender.
The second method did not work either; however, I did notice that after repeadedly turning on the ignition to try the first method the service message has now disappeared. I think this may only be temporary, due to so many ignition ons in a short period of time, so I'll try again later.
Also, I didn't realise that just pressing the trip reset before inserting the ignition key fires up the trip and odo recorders for maybe 10 seconds. Makes sense allowing to check the mileage on vehicles without needing the keys.
Finally, I noticed that on turning the ignition on but not starting the vehicle, after the service indicator goes out, and the the screen turns to the normal odo and trip recorders, the red oil lamp starts to flash on and off. I'm assuming this is linked to the service indicator.
Update - well it's several days after I tried the resets and I can confirm that the oil service indicator has not appeared again. I'm not certain now what the trick was but I think it may have been holding down the trip reset button before turning on the ignition and then turning on the ignition with the button still held down. I counted to 10 before releasing the button; but the reset may even be less than that.
Would be interested to see if anyone else can replicate this.
Post #295658 4th Jan 2014 12:06pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Just tried the 2.2 TDCI Ford Transit reset method and it worked first time Thumbs Up
Ignition on......pressed both brake and accelerator pedal down for 15 seconds.... Oil light started to flash. Turned the ignition off and left it for around 2 mins. Went back to the car and no more oil service indicator.
Post #308629 16th Feb 2014 5:55pm
RockJaw
United States 2013 Defender 110 Puma 2.2 SW Santorini Black
The best method is the Philips head screwdriver method.
Point the screwdriver in the direction of the oil service light. When everything is really well lined up you simply strike the back of the screwdriver handle firmly with a 22 oz hammer.
Works every time! ****CENSORED****
Post #308641 16th Feb 2014 6:26pm
sweepc
RockJaw I think thats the method used by some of the dealers Rolling with laughter
Post #308645 16th Feb 2014 6:29pm
RockJaw
I hear ya sweepc,
but I have known some dealers who don't even have the sophistication for the screwdriver, all they have is the hammer! ****CENSORED****
Post #308657 16th Feb 2014 6:44pm
sweepc
^ Rolling with laughter Rolling with laughter
Post #308670 16th Feb 2014 7:03pm
Page 2 of 3 <123>
