![]() | Home > Technical > Contaminated fuel problems new 110 defender 2007 |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5111 ![]() ![]() ![]() |
Yes but where is it!
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 ![]() ![]() ![]() |
I've barely had a chance to scratch myself today.... Saturday is full of much busy-ness and the new Defender is no excuse (apparently). Tomorrow I intend to carry out some further inspection to unravel this one. I will report back Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
That's how I read it. ![]() and that is what I fear ![]() '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
I had most of the day with my new English Mistress and she will do me. Spent a bit of time exploring:
The breather on the May build is now located on the rear RHD Driver's side inboard of the chassis rail behind the axle and above the fuel tank. The open end faces to the rear: ![]() Click image to enlarge Better? I figure that extending the all the breathers to the engine compartment is still a good idea. Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
Yes that looks worse to me! Mike
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 ![]() ![]() ![]() |
yes it looks no better to me ? It's more likely to to pick up spray from the front end as it looks like it's facing forwards.
Are they all like that or is that a one off ? Friday afternoon hodge ! Anyway after Reading all this I,ve been and sourced some long length of silicone hose in correct diameter to run to the front and up into the engine bay ! DEFENDER XS CSW 08 TONGA GREEN |
Chaser Member Since: 03 Aug 2008 Location: brisbane Posts: 9 ![]() ![]() ![]() |
I have had a look and moved my breather to the inside
![]() Click image to enlarge ![]() Click image to enlarge no water is getting into my system cheers chaser if it moves shoot it, if it dosn't push it. |
Just be careful of any fumes getting in Mike
yer I know what you are saying but the amount of air coming in through the seals will fix that. + in aussie we drive with the windows open most of the time.
As long as you are happy - ive seen a couple of people who have routed battery breathers and axle breathers into the cab and suffered fumes - axles can be really bad in the water Mike
ok its been a few weeks now, no fumes at all,(and no water in the fuel as well) it is winter here so the windows have been up all the time as well.
yes i am very happy with what i did cheers chaser if it moves shoot it, if it dosn't push it. |
Good to here - i routed mine out of the way some time ago - ill move it into the bonnet area in the future as a personal think I dont have breathers in the cab Mike |
