Home > Td5 > Remove anti-roll bar
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I'm thinking of removing the anti-roll bars on my 90.
I tried to remove the nuts that secure the bar to the axle, but the spigot just spins after the nut is loosened. What is the recommended way to get these nuts off..?
Simon
Post #292114 21st Dec 2013 8:27am
Mountain_man
Wales
IIRC they are the replaceable bits on the ends? Only a few quid to replace, so cut them off with a grinder!
Post #292121 21st Dec 2013 9:14am
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
If its the same as my 110, the roll bar is connected to drop links at each end which are connected to the axle.
Just undo the nuts/bolts remembering that the axle/link one is probably a castle nut with a split pin. Then apply Defender tool no.1 to persuade the bolts back through the bushes.
Should be really simple. Then you need to undo the bolts clamping the bar to the chassis obvs. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #292124 21st Dec 2013 9:24am
couplands
The trouble is that after I removed the split pin from the castle nut, after a few turns to loosen it the nut is turning the spigot (due to corrosion etc) and I cant see how to get another spanner on it to hold both ends...if that makes any sense.
I'm not keen on getting the grinder on it, but it might be the only option.
cheers
simon
Post #292137 21st Dec 2013 10:36am
K9F
Morning Simon,
I think you'll have trouble getting a grinder in. Cut off the rubber boot on the inner side of the drop link and see what is revealed. You may be able to get a pair of molegrips in there or a GS screwdriver or chisel to jam the spigot to prevent it rotating perhaps? Hope this helps.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #292141 21st Dec 2013 11:01am
Anderzander
I took mine off a couple of years back - I'll have a link at in the garage and see if I can remember anything useful.
Post #292148 21st Dec 2013 11:16am
couplands
K9F wrote:
Morning Simon,
Thumbs Up
Yeah, cutting the boot off and getting some mole grips on looks the way to go... Confused
cheers
simon
Post #292153 21st Dec 2013 11:32am
couplands
That would be very useful, thanks... Thumbs Up
cheers
simon
Post #292154 21st Dec 2013 11:34am
Macpaul
I think you need a socket and a spanner rather than two spanners. And a biggish socket at that.
Or just try and jam a big bladed screwdriver (or something) between the castle nut and the axle fitting and then use the spanner on the nut you can get to. 2003 Td5 110 Hardtop
Post #292155 21st Dec 2013 11:35am
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I took mine off last year, wish i had done it sooner! Much nicer ride down tracks and you dont really notice the difference in normal road driving.
All i did was slide the boot back and use mole grips on the shaft to stop it turning. Remember to use penetrating oil as long as possible before you start.
Pete.
Post #292231 21st Dec 2013 5:50pm
couplands
Yes, mole grips it is..Wink
cheers
simon
Post #292238 21st Dec 2013 6:09pm
jzk841
United Kingdom 2008 Defender 90 Puma 2.4 CSW Tonga Green
Did Molegrips Work ? I have the same issue... and about to try !
cheers Jon
Post #608358 10th Mar 2017 1:22pm
jzk841
could not wait.. used them... its off....
Post #608384 10th Mar 2017 3:31pm
couplands
Yes it did...glad it worked for you too... Thumbs Up
Simon
Post #608586 11th Mar 2017 11:44am
