Home > Puma (Tdci) > !#@!%$ Gearbox
CapeLandy
South Africa
!#@!%$ Gearbox
Seems like after reading all the posts on the gearbox issues, my Puma must have overheard and decided to follow her compatriots.
I just started noticing a rattle sound at low revs and more so when you change into 1st low and just let it crawl up the slope of the driveway.
Sounds like something loose inside the box.
Should I wait until the whole box destroys itself so LR are forced to install a complete new one or is it better to get it sorted sooner?
Appreciate some advice from those who have been down that road.
P.S Any South Africans had any such issues yet and if so what happened.
Thanks
James Puma 110 - gone
Series III 1973 - going strong
Post #2921 26th Jul 2008 7:54am
Daniel TD5
United Kingdom 1986 Defender 90 Other ST Nato Green
went to see my o7 double cab at the dealers
engine has the front missing and the gearbox is going to be replaced
your gear box won't blow up it will just get worst over time my one did
dealer will sort out land rover do know of the problem
dan
Post #2927 26th Jul 2008 1:31pm
CapeLandy
South Africa
Do they know exactly what the problem is and do they sort it on the replacement boxes or do they open yours and fix the broken or loose bits? Puma 110 - gone
Post #2929 26th Jul 2008 4:29pm
AndrewS
"Should I wait until the whole box destroys itself"
Well I suppose its easier to diagnose there is a problem if its in 20 bits in a cardboard box in the boot Razz There are TSB or GTR notes that are available to your dealer or anyone that subscribes. Stuff like. If a customer complains that the bla bla bla. The fix is Bla Bla Bla type thing. So call or take it to your dealer Thumbs Up
Post #2934 26th Jul 2008 8:48pm
CapeLandy
South Africa
Off to Dealers Thursday
I spoke to the technical guy at LR and asked if they had had any gearbox comebacks as yet.
They said they only had one gearbox which was the syncromesh on 2'nd gear and anoher which was clutch related - something aparently came loose.
I have her booked in Thursday and will revert once I have more info from them.
I also asked them at the same time to check why my idling changed sound from a quiet puma to a slightly more TD5 sound at idle and a very slight bit of hunting once she is warm. (barely noticable on the counter but you can hear the engine change tune slightly).
Post #2950 28th Jul 2008 11:49am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Re: Off to Dealers Thursday
James[/quote]
James I had something similar with mine not always running smooth, turns out it was a faulty fuel switch. Replaced under warranty and running fine now !
If you stand outside the vehicle and rev the trottle with you hand and listen carefully you will here it stuttering, thats what I showed them in the garage so they would fix it under warranty and not tell me they are all like that !!!!
N.
Post #2959 29th Jul 2008 8:47am
CapeLandy
South Africa
back at the dealer
Explained the whole senario again to technical dept. at LR.
The guy had a blank look on his face as I explained the problems to him. Shocked
Let's hope the sugestions I made registered in the grey matter. Sad Puma 110 - gone
Post #2986 31st Jul 2008 9:15am
CapeLandy
South Africa
good news
Mr. Green
Dealer found the clutch plate springs as well as the center plate have come loose.
Also the noisy idling has aparently been sorted by re-programming the correct injector codes again.
Problem is now he is waiting on LR in the UK to get a new clutch kit which could take 3 weeks. He is trying to get them to agree to fly the parts next week but will only know by Monday.
I hope I get a RRS as a loaner Whistle lets wait and see. Puma 110 - gone
Post #3004 1st Aug 2008 11:36am
The Badger
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Re: !#@!%$ Gearbox
Thanks
James
Weird this as I have got the same problem, put it in first and let the thing crawl and it sounds like something is rattling around on the inside of the clutch. Also is im just parked and press the clutch in, just as it releases I get this rattle, just at the top of the release. I can keep doing this and its the same noise.
defo sounds like something loose from the clutch?
Post #3047 4th Aug 2008 11:01am
mse
im interested i get this in 2nd pulling away when the engine should be just pulling hard but not rattling - i dont try it too often so keep forgetting, i would be interested to know more... Mike
Post #3055 4th Aug 2008 5:03pm
CapeLandy
South Africa
rattle
That's the exact symptoms I had. I have not seen the clutch plate yet so cannot comment on what exactly came loose.
I would get them to check it out, better news than replacing gearboxes.
The dealer has decided to refurbish the existing clutch and then later install a new one when it arrives.
Seems like double work to me. If I were them I would rather pay the airfreight from the UK then pay for loan car, refurbish of plate and then install the new one later.
But on the flip side I get to enjoy this
 Puma 110 - gone
Post #3061 4th Aug 2008 6:35pm
Daniel TD5
my 2007 double cab has been gone over three weeks now dealer still trying to sort out the clutch and gearbox noise
had a disco 3 loaner missed the canoes in devon no roof rack
they seem to be testing it with information from land rover and reporting back
the dealer and land rover have agreed tol replace the clutch and gearbox before they return it to me
dan
Post #3062 4th Aug 2008 8:34pm
The Badger
Dealer
Got my dealer to look at it tomorrow???
lets see what happens as it sounds like a loose bolt.
fingers crossed
Post #3068 5th Aug 2008 4:23pm
CapeLandy
South Africa
Clutch Plate
I was called on Wednesday to tell me the clutch plate had been reconditioned and would be fitted.
I asked to have a look at the plate before it was fitted.
Looked all secure with new springs (Inner and Outer) and new friction lining.
I aksed when they were getting the new clutch plate and was told that was no longer necessary as the recondition job would be better or good as a new one.
I said ok at the time but started wondering afterwards.
Would the manufactured springs be the same spec as the original seing as the repair would probably have been a clutch specialist but not an original part.
Also the lining material might not be to LandRover Spec.
I wonder if I should insist on a later replacement or just get them to sign a letter stating the above facts and that the warenty on the clutch and any other related problems will be their baby.
Any ideas. Puma 110 - gone
Post #3116 8th Aug 2008 5:57pm
mse
I would want a new genuine one, and to see the removed one to makesure it was fitted.
I may settle if they put in writing it is better than a genuine clutch and will not affect length of service or warranty. As then when it fails you have some comeback. Mike
Post #3119 9th Aug 2008 10:01am
