Home > Maintenance & Modifications > Removeable & cleanable noise muffling
BigWheels
Which is the best noise muffling to buy that can be removed & cleaned/allow the bare metal under to be cleaned?
Obviously sticky back stuff is not a consideration here. What I want is an additional muffle layer for under the OE carpets, to reduce road & transmission noise. (Bags of compost peat & bales of hay are effective in the rear load area, but not in the cockpit!) Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #290988 17th Dec 2013 2:04am
pannawonica
Australia
Dynamite is good, however not exactly remove able.
Post #291036 17th Dec 2013 10:47am
pannawonica
Australia
Excuse the typo it's called dynamat! Don't know where that came from I have n,t been on the grog yet!
Post #291038 17th Dec 2013 10:50am
jimbob7
I use 1.5 mm sheet rubber and foil camping mat but didn't stick it down (outa lazyness),why do you want to clean it underneath,if its stuck down it's not gonna get dirty?? Pov.spec,ftw. 2006, 110,TD5.
Post #291064 17th Dec 2013 12:34pm
BigWheels
I want a vehicle that can be hosed out & if necessary disinfected (being careful of sensitive areas naturally). So removeable everything, including sound proofing. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #291307 18th Dec 2013 12:40am
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Some parts of the Noise killer kits are removable.
Front Floors (NoiseKiller Sound Barrier)
Under Seats (NoiseKiller Sound Barrier)
Rear Floor/Load Space (NoiseKiller Sound Barrier)
You could try fitting the adhesive parts in reverse so they stick to the carpet instead of the bodywork; for example the part designed to fit the nearside wheel arch would fit to the carpet on the offside. That way the sound proofing will come out with the carpets.
Some pictures of the rear tub kit halfway down this page: http://defender90xs.blogspot.co.uk/2013/06...r-tub.html http://defender90xs.blogspot.co.uk/
Post #291318 18th Dec 2013 7:40am
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
I've got a mixture of Noisekiller and Dynamat (flexible metal sheet with strong adhesive backing) but the NK pads mean the rubber cab floor matting doesn't sit very well after installing.
Dynamat is much better and it is so sticky Im pretty sure you could still hose it out. Search a few photos on here to see what I mean. Ive probably got a little Dynamat offcut if you wanted me to post it to you to try it.. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #291331 18th Dec 2013 9:09am
landy andy
Don't go near noise killer kit if you want hose out. Holds so much water that it's permantly wet. Dynamat for me.
Andy
Post #291345 18th Dec 2013 9:58am
